Apple Tree Slabs
Forum topic by derrickparks57 posted 01-23-2016 06:34 PM 1281 views 0 times favorited 17 replies Add to Favorites Watch
View derrickparks57's profile
derrickparks57
129 posts in 1870 days
01-23-2016 06:34 PM
The apple tree in my backyard fell down before Christmas, I finally managed to cut the tree up a few weeks ago. I left the main part of the trunk with the plans to cut it up into a couple slabs with hopes I could make something out of it. Well I finally had a Saturday without it raining so I proceeded to tackle this thing.
Lessons learned:
1. I can’t cut straight with a chainsaw.
2. My bandsaw wasn’t really happy about resawing it.
I painted the ends and stickered it up so we’ll see what it looks like in about a year. If it doesn’t work out I’ll just chop it up and throw it in the smoker.
-- Derrick, Florida, DP Woodwerks
17 replies so far
View Kelly's profile
Kelly
2030 posts in 2943 days
#1 posted 01-23-2016 09:56 PM
We have thousands of acres of fruit wood here, in Eastern Washington. I just pulled a little cherry from the prunings in a friend’s orchard. Running it through the band saw, it pitched the wheels so bad I had to clean them to keep tracking where it belonged.
I have a lot of spurtles, wine stoppers, scoops and so forth made of apple wood. It’s a nice wood for kitchen utensils, since the grain is tight and has a lot of nice character.
Kelly
#2 posted 01-27-2016 04:06 AM
P.S. You have nothing to lose by treating all that flat area. It’ll lose moisture fast too. Just not as fast as the ends.
derrickparks57
#3 posted 01-27-2016 06:31 PM
Yeah I completely cleaned the bandsaw afterwards. We’ve had a good amount of rain lately and it was really wet, the sawdust stuck to everything.
View dhazelton's profile
dhazelton
2767 posts in 2295 days
#4 posted 01-27-2016 11:34 PM
Do folks usually slab fruitwood or make bowl blanks? Just asking as I have an apple tree that looks kinda sad.
Kelly
#5 posted 01-27-2016 11:42 PM
It all depends. I was in woodwork over forty years and never turned on a lathe until a little over a month ago. Prior to that, I slabbed all mine and used it for small things, like spurtles, spoons, band saw boxes, box joint boxes. . . .
Fruit trees get pruned every year and cut in ways not friendly to making lumber out of them. Too, everything commercial has gone the way of dwarf trees. You put more on an acre and end up with more fruit without having to climb fourteen foot ladders anymore. So its smaller pieces of wood, whether slabs or slices.
derrickparks57
#6 posted 01-28-2016 12:06 AM
This one fell down in a wind storm. The smaller stuff I cut up for my BBQ smoker but I figured what the heck lets see what I can get out of it.
View BurlyBob's profile
BurlyBob
5494 posts in 2264 days
#7 posted 01-28-2016 05:52 AM
That is truly beautiful wood. I sure hope you’ll be able to put it to good use.
View nicksmurf111's profile
nicksmurf111
367 posts in 1449 days
#8 posted 01-29-2016 04:57 AM
I tried squared up a sassafras log last year. I learned the hard way that I should have sealed the ends. It was way too much work to do freehand chainsaw work, and planing it so it was reasonably square. I probably should just avoid small logs/jobs.
Did you follow a string/level when you where chainsawing? I had trouble following a good reference line/plane on the first cut. I’m not sure if I want to invest in a chainsaw mill…there is a lot of kurf, and there are plenty of sawmill hobbyists in my neck of the woods.
-- Nicholas
View Mosquito's profile
Mosquito
9305 posts in 2291 days
#9 posted 01-29-2016 05:19 AM
If it were big enough to get quarter saw the size of a handsaw handle, that’s probably what I’d do with it, but that’s just me :-)
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
nicksmurf111
#10 posted 01-29-2016 05:26 AM
If it were big enough to get quarter saw the size of a handsaw handle, that s probably what I d do with it, but that s just me :-)
- Mosquito
I’m not following, could you clarify? Are you suggesting to handsaw it, or to take it to the sawmill if it’s large enough to make it economical? I imagine a handsaw handle is larger than 4 inches.
-- Nicholas
derrickparks57
#11 posted 01-29-2016 05:43 AM
I tried using a chalk line but since the log wasn’t straight it didn’t really work. Halfway through cutting it I realized that if I use the chainsaw to make a shallow cut down the length of the log it was easier to follow. Sort of, all the chips were getting in the way while I was cutting.
I ended up with a slab about 2 1/2” thick, 9” wide at the narrowest spot, and about 36” long.
nicksmurf111
#12 posted 01-29-2016 06:11 AM
I tried using a chalk line but since the log wasn t straight it didn t really work. Halfway through cutting it I realized that if I use the chainsaw to make a shallow cut down the length of the log it was easier to follow. Sort of, all the chips were getting in the way while I was cutting.
- derrickparks57
Yeah, that’s about the same experience I had. I think the longer the bar you have, the more chance you have to guide the freehand cut straight.
-- Nicholas
View LanternLightFarm's profile
LanternLightFarm
11 posts in 837 days
#13 posted 02-08-2016 04:12 PM
I’ve had luck using my chainsaw to cut small pieces of timber by making a frame out of 2×4’s that is the length of the log to be cut, it gets screwed to the ends of the log. I then hot glue 2, 1/4” spacers to my chainsaw bar to raise it just off the wood frame, and proceed to cut the first slab off the log. For successive boards just lower the frame the thickness of the slab you want to saw. Just make sure you have a sharp chain and plenty of time to make the cut!
View JoeinGa's profile
JoeinGa
7736 posts in 2006 days
#14 posted 02-08-2016 05:04 PM
DONT throw it in the smoker !!! How thick are those slabs? If you dont have a lathe , SOMEbody who does would LOVE to have those to turn !
View JayT's profile
JayT
5631 posts in 2210 days
#15 posted 02-08-2016 05:18 PM
- Mosquito
I m not following, could you clarify? Are you suggesting to handsaw it, or to take it to the sawmill if it s large enough to make it economical? I imagine a handsaw handle is larger than 4 inches.
- nicksmurf111
What Mos is referring to is that many vintage hand saws have quarter sawn apple wood for the handle. It’s hard to find any apple trees big enough to get wood to replace worn out and damaged handles, so if the tree were big enough, he would use it for that purpose. So would I.
