how do i fix a blotchy finish on walnut (pics included in the post)
Forum topic by shoichi posted 01-23-2016 04:34 PM 1398 views 0 times favorited 7 replies Add to Favorites Watch
View shoichi's profile
shoichi
30 posts in 765 days
01-23-2016 04:34 PM
i have a piece of walnut that i finished but looks terrible.. this is bad news because this piece is a gift that i am supposed to deliver in 5 days. the pics will show what the problem is: you can see towards the top that are spots of blotchy… looks as if enough oil did not sink into the wood.
what i did was i had oiled it with BLO, let it dry for a week then put a layer of watco’s walnut danish oil with a rag… let that dry for about a day..is there a way to mask this? i tried another coat of danish oil but still shows… i am thinking maybe i should have sealed it with shellac before putting the danish oil. terrible mistake but lesson learned…
what do i do now? below are some photos of the piece.
http://postimg.org/image/jjrwx39qd/
http://postimg.org/image/uxwn51n0t/
Edit: I forgot to add in the original post that I did apply one layer of dewaxed shellac as the last coat. Everyone is suggesting more coats. I hope the shellac won’t prevent penetration in the later costs
7 replies so far
View Pezking7p's profile
Pezking7p
3217 posts in 1554 days
#1 posted 01-23-2016 04:40 PM
Just needs more coats. End grain is thirsty.
-- -Dan
View gfadvm's profile
gfadvm
14940 posts in 2593 days
#2 posted 01-24-2016 01:29 AM
Picture doesn’t really show me the blotching as bad as you see. BUT I agree that you need to keep wiping on more coats.
View TheFridge's profile
TheFridge
8849 posts in 1389 days
#3 posted 01-24-2016 04:50 AM
More coats
shoichi
#4 posted 01-24-2016 07:20 AM
View OSU55's profile
OSU55
1513 posts in 1892 days
#5 posted 01-24-2016 02:26 PM
I don’t see blotchy. What I see is most of the surface has a thin film providing some sheen, then the spots were no film exists yet on the surface. More coats should fix it. Focus on the dull spots. keep them wet for 20 minutes or more. View in a raking light, use a brush, and just keep adding a bit of watco until it sits on the surface with no more absorption, then wipe off as normal. You can keep wetting the surface indefinitely and still wipe off. You may need to do some light wet sanding with 600-800.
shoichi
#6 posted 01-24-2016 05:02 PM
I don t see blotchy. What I see is most of the surface has a thin film providing some sheen, then the spots were no film exists yet on the surface. More coats should fix it. Focus on the dull spots. keep them wet for 20 minutes or more. View in a raking light, use a brush, and just keep adding a bit of watco until it sits on the surface with no more absorption, then wipe off as normal. You can keep wetting the surface indefinitely and still wipe off. You may need to do some light wet sanding with 600-800.
- OSU55
the damn problem now i have is that the danish oil won’t dry.. it’s been almost two days since the last coat and it still feels sticky tot he touch.. i am waiting for it to dry so i can apply another coat… i really hope the shellac i put on would not prevent the next coats from sinking in and evening out the unequal absorption of the previous coats
OSU55
#7 posted 01-24-2016 08:37 PM
Might try wet sanding with the oil. You cant leave much oil on the surface or it wont dry. The shellac will reduce oil absorption but not drying.
