How do you cut dog hole slots?
Forum topic by rwe2156 posted 01-23-2016 02:25 PM 792 views 0 times favorited 7 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
2958 posts in 1503 days
01-23-2016 02:25 PM
I’ve set up my radial arm with a dado at 88 degrees.
Made a test cut and (besides my dado set need sharpening) I wasn’t real crazy about it. Saw way underpowered even taking shallow passes plus it wants to self feed something fierse. Gonna try it with a 1/2” set up.
Not adverse to a router but I would rather not just because I don’t want to make a template and I don’t like the noise and sawdust everywhere.
I’m thought of using two crosscut blades with a spacer but that won’t work because RAS won’t accomodate it and doing it on the TS is too fraught with error.
So I’m thinking I will cut two passes and remove material with chisel and router plane. I can use a spacer so slots will be uniform.
This is hard maple.
Tell me how you did yours – No, I don’t want to do round holes ;-)
7 replies so far
View builtinbkyn's profile
builtinbkyn
2362 posts in 963 days
#1 posted 01-23-2016 02:47 PM
Just make multiple passes with a crosscut blade if the saw is struggling with the dado stack. Then clean out with a chisel.
-- Bill, Yo!......in Brooklyn & Steel City :)
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1199 days
#2 posted 01-23-2016 03:50 PM
If you are speaking of bench dog holes I went with round holes to simplify the matter.
I had the same problem with a radial arm saw. Also mine wanted to flex enough so the depth of the dado would change front to back.
View MT_Stringer's profile
MT_Stringer
3172 posts in 3253 days
#3 posted 01-23-2016 04:08 PM
Tell me how you did yours – No, I don t want to do round holes ;-)
- rwe2156
Mine turned out nice.
I bored two holes for each slot. Then connected them with a line for each side of the slot and cut away most of the waste with a jig saw. Then I used pieces of 1/2 inch mdf to form a template and ran a flush trim router bit around the inside of the template.
Later, after laminating the top, I use a pattern bit to cut away the excess Formica, and followed it with a chamfer bit set really shallow so it only eased the edge of the Formica.
It takes a little time and work, but if you want the result to look good, you got to do the time! :-)
Here is a link to my project. There is a link to my blog which I described the build and posted a lot of construction pics.
http://lumberjocks.com/projects/92907
rwe2156
#4 posted 01-26-2016 02:35 PM
- builtinbkyn
Thats what I ended up doing. Came out satsifactorily.
View splatman's profile
splatman
586 posts in 1421 days
#5 posted 01-26-2016 07:45 PM
- rwe2156
Can you slide it all the way out, place your stock, then cut on the back stroke?
View ScottM's profile
ScottM
654 posts in 2169 days
#6 posted 01-26-2016 08:45 PM
Multiple single passes with a rip blade. It leaves a flat bottom.
View conifur's profile
conifur
955 posts in 1174 days
#7 posted 01-26-2016 10:06 PM
ABSOLUTELY NOT, the rotation of the blade will want to pick the piece up. Joys of dadoes on a RAS.
