Drawer Bases
« back to Joinery forum
Forum topic by EdsCustomWoodCrafts posted 01-23-2016 02:55 AM 705 views 0 times favorited 9 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
778 posts in 1342 days
01-23-2016 02:55 AM
So I’m hoping someone is up.. I think I made a error in my drawer design and craftsmanship
I’m making a drawer to fit inside a 36” wide cabinet and I’m using 3/4” or 13/16” as I’ve come to realize
Any way I cut all 4 panels to the drawer to final size and I measured 1/4” up from the bottom of each panel and cut 1/4” dado to receive a 1/4” plywood base panel but I made it 1/2” deep…
IS THIS TOO DEEP..
I don’t think there will be anything extremely heavy going into the drawer but then again one never know how much weight might end up in the drawer
Any advise very welcome I’m thinking I have to redo do both drawer components and cut 1/4” dado 1/4” deep
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
9 replies so far
View TheFridge's profile
TheFridge
9468 posts in 1485 days
#1 posted 01-23-2016 03:13 AM
Dado 1/2 the thickness is what I was taught. I’d put thicker material for the bottom of a 36” drawer for shop cabinets. (If it’s a shallow drawer (12” or so) I prob wouldn’t worry about thicker bottom material)
So unfortunately I’d vote for yes. Redo bottom and sides. Undersized ply is the rule not the exception. And double check thicknesses of all your ply and pre milled lumber to try to avoid similar mistakes.
View jbay's profile
jbay
2288 posts in 898 days
#2 posted 01-23-2016 03:15 AM
I don’t think it’s too bad. If your worried just cut off the dado and run a new one. Can your drawer be 1/2” shorter in height? I wouldn’t remake them. Worst case scenario would be to glue strips back into the dado and recut them.
View conifur's profile
conifur
955 posts in 1150 days
#3 posted 01-23-2016 03:18 AM
You are fine, the general rule is cut it about half the thickness, in your case if I understand would have been 3/8 deep, you could take a 1/4” thick by what ever wide strip going across the bottom of the drawer to add support also.
EdsCustomWoodCrafts
#4 posted 01-23-2016 03:19 AM
I don t think it s too bad. If your worried just cut off the dado and run a new one. Can your drawer be 1/2” shorter in height? I wouldn t remake them. Worst case scenario would be to glue strips back into the dado and recut them.
- jbay
What if I didn’t cut that end but flipped inside out sour the 1st dado is on the top of the outside face and recut a 1/4” dado a 1/2” up from bottom
View sawdustdad's profile
sawdustdad
354 posts in 884 days
#5 posted 01-23-2016 03:25 AM
You will be fine with the 1/2 in deep dado. glue the panel in. Next time, cut 3/8 in deep dadoes.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
EdsCustomWoodCrafts
#6 posted 01-23-2016 03:31 AM
- sawdustdad
Thanks sawdust dad …???? I don’t why I did it s deep .. What I might do is reverse the panels so as that the first dado is on top outside panels of the drawer box and redo… 1/4” deep 1/2” up from bottom …I spend a good bit on doing a good job on this to have a feckin drawer ruin it
View Mark Kornell's profile
Mark Kornell
1169 posts in 2530 days
#7 posted 01-23-2016 04:09 AM
Just go with the 1/2” dado, make the bottom a nearly perfect fit and glue the bottom in all the way around.
Most drawers are make of 1/2” stock with 1/4” thick bottoms in 1/4” deep dados. With the.dados you cut, you left the same amount of meat in the drawer side as is normal practice. Plus you’ve got some extra glue surface.
-- Mark Kornell, Kornell Wood Design
View rwe2156's profile
rwe2156
2925 posts in 1479 days
#8 posted 01-23-2016 12:48 PM
Not to the subject at hand, but I agree with Fridge re: bottoms too thin.
View builtinbkyn's profile
builtinbkyn
2281 posts in 939 days
#9 posted 01-23-2016 01:43 PM
This entire cabinet is made of 1/2” ply – drawers and all. I could park my truck on it. You are fine.
Edit: Just re-read the OP. 1/4” drawer bottoms with a dado that goes thru the sides deeper than 1/2 the dim. of the sides. Man I need to have my coffee before posting in the morning.
-- Bill, Yo!......in Brooklyn & Steel City :)
