Harbor Freight Spindle Sander
Forum topic by Tom posted 01-23-2016 01:44 AM 1849 views 0 times favorited 23 replies Add to Favorites Watch
View Tom's profile
Tom
174 posts in 1025 days
01-23-2016 01:44 AM
I’ve been looking at getting a spindle sander for a while and got a coupon for a HF for $99. While in the store I was asked by two people if I was considering the warranty. I asked them is it that low quality? They wouldn’t say yes or no but emphasized if it broke in the first 2 years I had it they’d replace it.
Question: is this possibly junk that I should just save my $$, do I spend $20 on a warranty, or do I just keep it and roll the dice to see if it breaks in the first 3 months I have it?
23 replies so far
View jmartel's profile
jmartel
7804 posts in 2115 days
#1 posted 01-23-2016 02:14 AM
It’s way underpowered. Mine hasn’t broken yet, though.
Buy the Rigid one that’s a combo spindle/edge sander. Much better.
View MrUnix's profile
MrUnix
6588 posts in 2164 days
#2 posted 01-23-2016 02:28 AM
Extended warranties are almost pure profit for retailers, which is why they push them so hard. Most defects will be discovered early, within the standard warranty period.
View tomd's profile
tomd
2148 posts in 3735 days
#3 posted 01-23-2016 02:37 AM
I have had one for several years now, don’t use it much but no problems.
-- Tom D
View AZWoody's profile
AZWoody
1325 posts in 1189 days
#4 posted 01-23-2016 02:40 AM
It s way underpowered. Mine hasn t broken yet, though.
Buy the Rigid one that s a combo spindle/edge sander. Much better.
- jmartel
I have that and the edge sander is great but the spindle sander is a weak point in my opinion. The sleeve always wants to spin on the spindle and was very frustrated. I ended up buying a dedicated free standing spindle sander.
View JayDee70's profile
JayDee70
19 posts in 1283 days
#5 posted 01-23-2016 02:51 AM
I have this WoodCraft WoodRiver bench-top which if you catch it on sale it is less then the HP unit. I have used it for about a year or so and have had no problems with it. There are others that look just exactly like it except color and I think the Rigid is one of them. I have never had one so I can’t directly compare but it seems to have power enough for my needs plus I have never had any trouble with the cylinder slipping unless I have forgotten to tighten down the retaining nut. H,YMMV
-- JD, KY, www.jnjwoodsmithing.com On FaceBook at https://www.facebook.com/jnjwoodsmith
View rwe2156's profile
rwe2156
2881 posts in 1446 days
#6 posted 01-23-2016 12:51 PM
Spend an extra $100 and get the Ridgid.
Oops someone already said that.
Check CL I’ve seen a couple for <$100 in my area.
View JeffP's profile
JeffP
573 posts in 1357 days
#7 posted 01-23-2016 01:04 PM
For big machines that cost a lot, buying “the best one” vs. “getting by with the cheapest one” can be a daunting decision. It’s one that most of us have pulled out hair over.
With a low cost tool like a spindle sander, I think it is much easier. When the best one is still cheap, it is to me a no-brainer.
For that reason, I give a +1 to the Rigid model already mentioned. Even though it is not the least expensive, it is still dirt cheap and works really well.
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
View Tennessee's profile
Tennessee
2860 posts in 2480 days
#8 posted 01-23-2016 01:05 PM
I own two of the old style, which look identical to the Grizzly offered for $134.95.
They both run great, and although I also have the Rigid combo, I use it almost exclusively in belt mode. The two HF units I both bought with coupons for less than $90 each.
About 18 months ago, Harbor Freight changed the design, going to what they have now:
Almost immediately, the reviewers started complaining that it was underpowered, and a fair amount of them were failing. I personally thought about buying a third since I use them a lot but when I saw the reviews I did not buy another. I would stay away from the new style. Maybe go with the Grizzly, which I believe is the old HF unit in new paint.
View bbasiaga's profile
bbasiaga
1200 posts in 1960 days
#9 posted 01-23-2016 02:33 PM
My brother has one of the HF units. I suspect it is the newer type. He isn’t a heavy user but he seems pleased enough. That is kind of the deal with HF. You spend less, and it may not be perfect. But if its something you don’t use all the time it may be worth it.
There is always a consideration that you should stay away from any of the ones that look identical, if you don’t trust one of them. Its because they are identical. The HF, Grizzly, Craftsman, Jet etc likely all come from the same factory. Higher priced brands may hold them to higher specs, or upgrade small things like belts and motors. But structural flaws are likely to be shared by all. ]
-Brian
View dhazelton's profile
dhazelton
2755 posts in 2262 days
#10 posted 01-23-2016 02:40 PM
I bought one and it was DOA no matter what outlet I tried it on. I took the bottom off to see if the switch wasn’t wired in or something simple and saw how dinky the motor and workings are. ALL the mass is in the top. I found a barely used JET for $200 and was much happier – metal gears in an oil bath versus the plastic gears on the HF.
As far as a warranty, if I was going to use the living heck out of it chances are up there that you will kill it within 2 years, so I say get the warranty.
View Tom's profile
Tom
#11 posted 01-23-2016 05:55 PM
The model I got was 62146 and the one on the HF site is 69257. It looks like it is the “newer” model with the red plastic bits instead of the yellow. I did look at the Rigid belt/spindle sander and watched some YouTube reviews of both…and I’m starting to think the Rigid is the better option even if 2x as much since it’s more than twice the functionality of the HF tool. I’ve checked CL for used…but the selection is pretty thin…as in one that’s an hour drive away. I could get my wife to agree to the $100 for the sander…but $200 is pushing it. Might have to pick up some OT to justify the extra $$ I want to spend.
View conifur's profile
conifur
955 posts in 1117 days
#12 posted 01-23-2016 06:28 PM
79$ on sale with a rebate, I have one from Menards, same thing as HF I suspect, no problems.
View Steve Peterson's profile
Steve Peterson
371 posts in 3047 days
#13 posted 01-23-2016 07:16 PM
The casting of the old design may be the same as the Grizzly, but I bet HF uses a smaller motor to hit a lower price point.
-- Steve
JayDee70
#14 posted 01-23-2016 07:30 PM
For those that might be interested, some research.
I was looking for a digital version of the manual for my WoodRiver spindle sander but could not find one so got to wondering if the manual for a different brand would be just as good. I down loaded three different manuals for similar looking machines and review them and found that they were pretty much identical except for the first page showing the brand name. Yes there were some differences in the text but they all covered the same subjects in their on ways but when you get to the parts list and exploded views they were identical right down to the item numbers. For example item (57) is the wheel(cam) that raises and lowers(oscillates) the spindle. So I think I have usable manual(s) for my WoodRiver machine. Just a quick google of “oscillating spindle sander” found no less then eight more or less identical machines plus another group of similar ones but with round table tops that I would bet a dime to a doughnut are also identical and may even have the same workings inside as these. Several of these are reviewed on Amazon and if I were in the market for another one I would forget the brand name and go with the best reviewed one. WoodRiver BTW gets pretty good reviews. Here is combo pic for reference.
View PeteStaehling's profile
PeteStaehling
49 posts in 1085 days
#15 posted 01-23-2016 07:44 PM
Some months ago when I was looking into a spindle sander. I was considering the Rigid, but I saw numerous reviews that said the motor was either DOA or failed within a week.
I then bought a Triton. It has worked well for me. It looks just like the Grizzly to me.
