Delta TS 36-474 & 36-441C
Forum topic by csask posted 01-22-2016 09:06 PM 1673 views 0 times favorited 12 replies Add to Favorites Watch
View csask's profile
csask
8 posts in 757 days
01-22-2016 09:06 PM
Hi all, I have come across some Delta saws for sale, one 36-474 and two 36-441Cs. I haven’t been able to find out a whole lot about them online. The 36-474 looks to be a higher quality saw, so I was drawn more to that one. All three have Uni-fences and look to be in approximately the same shape (they came from a shop that modifies vans into campers so I’m thinking they would have mostly ripped a lot of plywood only).
Can anyone speak to the quality of these saws, and what price would be reasonable to pay for them?
Thanks!
12 replies so far
View knotscott's profile
knotscott
7870 posts in 3277 days
#1 posted 01-22-2016 09:25 PM
I’m not familiar with either of those models off the top of my head, but if they have a belt drive outboard 1.5hp induction motor, are 27” deep, and have a Unifence, they could all be good functional full size contractor saws with nice fences. Condition, age, and completeness determine their actual value. Solid cast iron wings are worth more than steel, mobile bases, and extra inserts are nice to have. Having the original miter gauge or a good after market miter gauge would add some value vs not including it. Having the original blade guard is nice too. A broad price range assuming they are true contractor saws, and not compact saws with a direct drive motor, would be roughly $200-$500… depending….could be lower if they’re trashed, but it’d take like new condition and some good extras for them to be worth much more IMO. How much are they?
csask
8 posts in 757 days
#2 posted 01-22-2016 09:42 PM
Thanks knottscott, I didn’t see a miter gauge with it, but I can ask. It has a 1 1/2 HP outboard as you describe. I have also added a picture as well. I’m fairly new to the game and would like to replace my Craftsman TS if this is a good price. It sounded like the owner would let it go for ”$400 – $500, so I take that as $400. Also, note I am in Canada and equipment up here always seems to be more expensive than you folks to the south.
Thanks for the advice!
knotscott
#3 posted 01-22-2016 09:55 PM
That looks pretty sweet to me….solid cast wing, nice extension table, looks to be in very nice shape, nice fence. Stock miter gauges aren’t usually all that good anyway, it was just used as an example of what adds or detracts from value. IMO that’s a buy at $400. You can get a decent miter gauge for ~ $60, and decent blades start at ~ $30.
csask
8 posts in 757 days
#4 posted 01-22-2016 10:42 PM
Pulled the trigger and got it for $350 :)
Thanks knotscott!
View rubber_ducky's profile
rubber_ducky
36 posts in 779 days
#5 posted 01-22-2016 10:48 PM
Nice work. That’s a great price. I just bought the same saw, but in need of much more TLC for $300. $350 cad for your saw seems like a better deal
knotscott
#6 posted 01-23-2016 12:01 AM
Thanks knotscott!
- csask
Nice….good for you. Check the alignment thoroughly, and get a decent blade for it. Congrats!
View Rick_M's profile
Rick_M
11077 posts in 2281 days
#7 posted 01-23-2016 12:04 PM
I have a 36-477 which looks nearly identical to the saw you bought. I’ve owned mine for over 15 years and it’s still going strong, I’ve never wished for anything else.
-- http://thewoodknack.blogspot.com/
csask
8 posts in 757 days
#8 posted 01-24-2016 10:13 PM
Thanks for your feedback guys. Next question, the saw is currently wired for 240 but I don’t currently have a receptacle in my garage for it. I can wire up a dedicated 240/15 or 20 amp plug for it easily enough (it only draws 8.4 A on 240 I believe). Does it make that much of a difference? If so, should I go 15 or 20 A? At the moment I don’t see why I would need more than 15A service.
Thanks!
knotscott
#9 posted 01-24-2016 11:23 PM
If its just a matter of wiring up a 240v outlet, I’d definitely go for it….should be no harder than rewiring the saw back to 120v.
View RibsBrisket4me's profile
RibsBrisket4me
1555 posts in 2407 days
#10 posted 01-25-2016 12:42 AM
Csask, you picked up a very nice saw at a very nice price, congrats!
RibsBrisket4me
#11 posted 01-25-2016 12:44 AM
Add a MJ splitter and a mitre gauge of your choice, Inrca, Kreg, etc, and you are good to go!
View Sparks64's profile
Sparks64
7 posts in 787 days
#12 posted 01-25-2016 07:18 AM
The cost for putting in a breaker and outlet 15a vs 20a is nominal. If it were me , I would go with the 20a…. allowing for future equipment.
-- Sparks64,Oregon
