Mortiser Getting Stuck
Forum topic by Adam Baird posted 01-22-2016 05:56 AM 641 views 0 times favorited 6 replies Add to Favorites Watch
View Adam Baird's profile
Adam Baird
63 posts in 2022 days
01-22-2016 05:56 AM
I picked up a Wood River bench top mortiser on Craigslist last week. Its been great so far, but I was cutting mortises tonight and, all of the sudden, the mortiser will not descend regardless of how much downward force I apply.
Even if I remove the workpiece entirely, I get a grinding noise and I can barely get the bit to move down at all. I can get it to go up without any trouble though. I’ve tried playing with the tightness of the runners that the mortiser moves vertically on and that doesn’t seem to have any affect. I’d prefer not to take this thing all the way apart, but can’t figure out what the issue is without doing that.
Anyone have similar experiences?
-- Adam from Indiana - http://www.WoodenUnion.com
View conifur's profile
conifur
955 posts in 1055 days
#1 posted 01-22-2016 06:34 AM
There is a stop rod, to set for depth, is that in the way, pics would help
Adam Baird
#2 posted 01-22-2016 06:57 AM
The stop rod is removed completely at this point. That was one of my first thoughts as well, but is not what is causing the issue.
Its hard to give you a picture of what’s happening. Everything appears correct, but when the bit gets even with the hold down (approximately 4” above the cast iron table) it starts grinding heavily and then stops completely after moving another 1/2” or so. Any ideas?
conifur
#3 posted 01-22-2016 07:41 AM
Stumped, is the bit chucked tight? No idea at this point, I have a Delta, they are all basically the same.
View rwe2156's profile
rwe2156
2794 posts in 1384 days
#4 posted 01-22-2016 11:58 AM
Call Woodcraft they are usually pretty good with customer service.
I’m stumped. Have you checked the rack and pinion and travel ways maybe something is lodged in there?
View Tennessee's profile (online now)
Tennessee
2739 posts in 2417 days
#5 posted 01-22-2016 12:08 PM
Just looking at online reviews, there have been some complaints about hub teeth breaking off and jamming the rack and pinion, and issues on the brass shims being too tight, knocking it offset so it jams.
Since it gets jammed at one point, but will lift off of that, I’d be looking for something jamming inside, or possibly a broken tooth on the rack or hub.
Adam Baird
#6 posted 01-22-2016 01:28 PM
Thanks all. I’m guessing its something jammed in the rack and pinion, but was hoping to avoid disassembly today. I suppose it could be worse.
