Start a new project, Buy a new tool
Forum topic by Karson posted 1030 days ago 837 views 0 times favorited 20 replies Add to Favorites Watch
25806 posts in 1298 days
1030 days ago
There had been some discussion on some of the blogs and projects that the way to increase your tool count was to buy a new tool when you start a new project.
I commented that it doesn’t require that the tool be used in that project, only that you purchase one.
So this is my new purchase. It’s a dowel cutting tool. It’s the Veritas Dowel Maker I purchased the complete kit called Master Dowel Maker Kit.
I started to work at the Mason Dixon Woodworkers Club toy making on Wed. They work in the shop one day a seek, until it get close to Christmas. Then it might require other days. Some people also work in their own shop. Tonight I was cutting walnut wheels for a toy truck (400 Wheels).
The dowels will be used for the headlights and were made out of cherry stock. They make around 1200 toys to be given to charities and hospitals at Christmas time. They’ve done this for 11 years.
You cut square stock 1/8” bigger than the finished dowel. I’ll also make some 5/16 walnut dowels this week for the axles, so it will require 1/2” walnut.
Once you get the machine knives adjusted the dowels come out polished. I took the machine over to the workshop on Wed and 5-6 people tried it out.
It won’t pay if you only need walnut or cherry or maple dowels. But I do a lot of imported woods where you couldn’t buy dowels of that species unless you really paid through the nose. Like Pink Ivory or Ebony dowels.
It leaves about 5” at the end that is still square or partially round. So I’m trying to think of a way to grab the finished dowell and continue pulling the stock through. I could do that up to 1/2” with a drill, but 5/8 is too big. Maybe sand it down for 1” and then chuck it in the drill and run the drill in reverse to finish and capture all of wood. So lose 1” to gain 5”, sounds like a good tradeoff. A 1/4” dowell might shatter if put under too much torque pressure. But that’s the fun of experimenting.
Not that I’m selling but if you do need some wierd dowel and we can come up with the wood. I’m willing to help. Like Don’s bamboo pins that he used in his box.
The tool will cut from 1/4 to 1” by 1/16 but you can cut over and under size so almost any size might be possible.
14171 posts in 1059 days
1030 days ago
now isn’t THAT interesting (and I never thought of making my own dowel thingy for my little heart box… )
That’s quite an amazing group you are part of—what a wonderful gift you give the community.
View oscorner's profile
oscorner
4572 posts in 1209 days
1028 days ago
You could have purchased a lathe and had a tool that would have done more. Of course, depending on the length of your dowels, 1/4” would be tricky in lengths over 12” without some support in the center while turning. It’s just a thought, because I use my lathe to turn dowels when I need one right a way or of a size that is not readily available..
My hat is off to you and the Mason Dixon Woodworkers Club’s charity work.
-- Jesus is Lord!
1028 days ago
Oscorner: I need to make 120 ft of 5/16 walnut for the axles and it takes about 20 seconds to turn a 3’ section. Lathe is an option but it would be hard to beet this jig for some small production runs.
View Obi's profile
Obi
2191 posts in 1135 days
1028 days ago
I started making my own dowels with my cordless drill. I had a hole. I got a piece of square scrap, cut the stick down to about 6-8” and stuck it in the end of the cordless drill with a piece of 60 grit sandpaper and squeezed the trigger. When you don’t have much money to spend but have a lot of sticks and time on your hands, it was kinda like sandpaper lathing. I’d sand while I watched videos on my computer. It also works when you need a special dowel made from a special wood. I’m just getting started and have to make due with what i have, until the Money Boat reaches my port.
And the guy that has me build all the stuff just so he can justify giving me money without making me feel like a charity case said he wanted me to build a mission style table for his remotes (and a mantel for his fireplace, and his kitchen cabinets, and a wind stop for the fireplace hole to stop the wind from rushing into his front room) and I told him I wanted to do mortise and tenon but needed the bits for which I am short of funds so he’s going to order them for me. God must really, really, really like me to give me such good friends, and surround me with such Quality People.
-- http://ye-olde-cabinet-shoppe.com/
View Obi's profile
Obi
1028 days ago
There’s no way you can make 3’ of 5/16 dowels on a lathe in 20 seconds. That tool can NOT be beat for the purpose you bought it for. Good Buy, Karson.
oscorner
1028 days ago
I beg to differ. If you start with 1/2” stock and at 1000 rpms, it goes pretty fast. But, Karson knows what works best for him. My main point was that for the money, he could have bought a machine that would have done more, that’s all, Obi.
-- Jesus is Lord!
View Obi's profile
Obi
1028 days ago
Maybe I should have said there’s no way I could have made 3’ of dowel in 20 seconds
View scottb's profile
scottb
3402 posts in 1225 days
1028 days ago
I like your sentiment Karson… but unless the tool figures into the project I’m afraid the wife would surely veto the purchase (If it doesn’t magically appear that is). Maybe that’s why I keep such a diverse list of projects, some to show I’ve got everything I need and others that only need “one little” thing. :)
View Bill's profile
Bill
2561 posts in 1059 days
1005 days ago
That is a nifty tool you picked Karson. Maybe you can use the end bits to turn pens or something. Then you would not waste the wood.
Obi, that was a good economical idea! I will have to keep that in mind next time I need a dowel.
View gizzard's profile
gizzard
46 posts in 1051 days
1005 days ago
When I first started making rustic stuff, I drilled a 1/4” hole in an old framing square. I’d rough out a dowel with a carving knife and when I got close to 1/4” I’d pound the roughed out dowel through the hole in framing square. Worked just fine. Now I’ve read where you can purchase steel plates with various sized holes to make dowels doing exactly the same thing. I didn’t invent this method. I read about it somewhere and gave it a try.
I wish we had something like you all have Karson. I like making toys. Keep up the good work.
-- Dennis, Tennessee
Dick, & Barb Cain
7044 posts in 1197 days
1005 days ago
I made a jig for making 1/2” dowels, when I built my Windsor chairs. It’s very simple. You mount a router on it, If anyones interested I’ll take an image of it. You can make a different jig for each dowel size.
View Don's profile
Don
2590 posts in 1075 days
1005 days ago
Count me as interested, Dick.
-- CanuckDon "I just love small wooden boxes!" http://www.hilsbiblechurch.org/
View Bill's profile
Bill
1003 days ago
I would like to see that plan too Dick!
View Obi's profile
Obi
1003 days ago
i’M INTERESTED TOO, dICK I wanna be the Dowel King of Central California
View Obi's profile
Obi
994 days ago
I didnt have the $300 to buy your fancy riggin’ so I ordered this one instead
View jockmike2's profile
7352 posts in 1145 days
994 days ago
Dick, how thick do you recommend the steel to be to drill your own holes in it for dowls?
-- Mike. mwurm13@yahoo.com
View WayneC's profile
WayneC
6044 posts in 995 days
993 days ago
For smaller pins, I bought a dowel plate from Lie-Nielsen. You drive wood through the plate with the hammer. I’m not sure that it is really a cheap option, but I have a thing for Lie-Nielsen tools.
View Bill's profile
Bill
993 days ago
Obi, did you get the socket set to go with it, so you can hook it up to your drill?
View Obi's profile
Obi
984 days ago
Bill,
Bought the socket, but didn’t need it. Just clamp the wood in the drill chuck and run it through the dowel maker. That way I don’t have left over wood. After I run it through, I turn the dowel over and stick it in the other end, and do the last 4 or 5 inches.
View BassBully's profile
BassBully
253 posts in 995 days
983 days ago
Karson,
I get new tools with new projects too but I try to purchase the tools that I need for the project. That’s how I’ve been able to get my woodworking tools and automotive tools. Instead of paying a mechanic $50/hour to fix my car or pay a couple of hundred dollars for a piece of furniture, I do the work myself. The money I save, I invest in tools.
-- There are three types of people in the world, those who can count and those who can't!
