need a pulley for a 4" Rockwell/Delta Jointer
Forum topic by John Ormsby posted 01-30-2010 07:00 PM 9256 views 0 times favorited 25 replies Add to Favorites Watch
View John Ormsby's profile
John Ormsby
1288 posts in 3822 days
01-30-2010 07:00 PM
Topic tags/keywords: jointer
Hello all,
I have brand new old stock Rockwell 4” jointer with an open stand. It came with the wrong motor and pulley. I found a new 1725 rpm motor and am now looking for a pulley. Does any one have one of these jointers with the 1725 motor and larger pulley? I am trying to find out the diameter of the pulley .I believe it is about 6” diameter but am not sure. Your help would be much appreciated.
Thanks, John
-- Oldworld, Fair Oaks, Ca
25 replies so far
View davidpettinger's profile
davidpettinger
661 posts in 3285 days
#1 posted 01-30-2010 07:08 PM
Hey John, do you have a model number. Maybe with that there will be a way to find a manual that will give us an idea.
-- Methods are many,Principles are few.Methods change often,Principles never do.
View Dusty56's profile
Dusty56
11819 posts in 3773 days
#2 posted 01-30-2010 08:46 PM
My old Delta-Rockwell 6” jointer has a 1/2” x 7” pulley on the 1725rpm motor and a 2&3/4” pulley on the cutter head.I know you have the 4” , but I am assuming that in the end , they would turn at the same rpm’s.
John Ormsby
#3 posted 01-30-2010 08:48 PM
I have the instruction manuals for this jointer and the stands.
I have the 50-290 open stand. The jointer came with this stand. I have the correct motor for the other stand ( 50-518 ) which uses the 3450 motor and 3” pulley. I can use this on the other open stand. However, the stand 50-290 shows the 1725 motor and larger pulley. I might just use this 3450 motor and pulley and get the link belt pulley to reduce the vibration. The manual for my stand does not indicate the size of the pulley. The manual for the motor and pulley I have states the pulley size (3”).l
John Ormsby
#4 posted 01-30-2010 08:53 PM
Dusty56, are you sure the shaft is 1/2”? Both of my motors have 5/8” shafts. I think the 7 1/2” would be the same pulley for both jointers. The cutterhead diameters are probably the same for the 4” and 6” jointers.
Dusty56
#5 posted 01-30-2010 09:00 PM
I’m sorry , the 1/2” measurement that I gave was for the V-Belt….let me see if I can measure the shaft diameter for you : )
Dusty56
#6 posted 01-30-2010 09:25 PM
Yes , the shaft is 5/8” , but the pulley is only 7” as stated above . : )
John Ormsby
#7 posted 01-30-2010 09:33 PM
Thanks Dusty for the info.
Now the search goes on for the pulley.
Does anyone have a 7 1/2” diameter x 5/8” bore pulley for sale?
View MarkwithaK's profile
MarkwithaK
370 posts in 3263 days
#8 posted 01-30-2010 09:37 PM
Check with Grainger.
-- If at first you don't succeed then maybe skydiving isn't for you.
View Jeison's profile
Jeison
968 posts in 3193 days
#9 posted 01-31-2010 05:51 AM
may also want to try eReplacementParts.com and Tool Parts Direct
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
View mcguiver's profile
mcguiver
6 posts in 2847 days
#10 posted 11-04-2010 09:30 PM
Since I am a new member, I will now dive in. I am finishing a restoration on a Delta 37-290, 4 inch jointer and trying to figure out the correct motor and pulley size. So, a 3450 RPM motor can use the smaller 2 3/4” pulley with a link belt or a 1725 RPM motor with the larger mystery pulley with the mystery shaft size. Currently, I have a sears motor that has a 5/8ths shaft at both ends. It probably came from a dual tool use platform. I am assuming that one end of this incorrect motor is used to drive the jointer and the other end will eventually be used to bring me to the emergency room after it winds my pants leg up. Let me know where you found the pulley. I need the 7.5 inch one with spoke wheel if possible. It will make all of my wood projects look better if I feel better. Putting an Ace hardware, washing machine pulley on a Delta 37-290 would be a sad day for this cast iron beauty. Might as well make a pulley out of wood…
-- Brian, Greensboro, NC .....A lie is not a lie if the truth is not expected...
mcguiver
#11 posted 11-04-2010 11:13 PM
Thanks Rick. Very helpful. So, you don’t think that a 3450 rpm with a 7 inch pulley driving a 2.75-3 inch inch jointer pulley will make it go too fast?
I would hate to have my jointer look like the Rolls Royce engine on that Airbus A380 this morning!
John Ormsby
#12 posted 11-05-2010 12:13 AM
The original size pulley for a 1750 RPM motor is 2.75” on top and 6” on the bottom. I would NOT put a 3450 motor with this pulley configuration.
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3192 days
#13 posted 11-05-2010 02:35 AM
John,
Applied technologies.com has just about any pulley or bearing you can think of and they are everywhere. Rand
mcguiver
#14 posted 11-05-2010 09:20 PM
Thanks for all the tips,
I just purchased my bearings from Applied. They were a little expensive but they were the exact bearings required with the extended collar.
View MedicKen's profile
MedicKen
1615 posts in 3547 days
#15 posted 11-05-2010 09:30 PM
John…..Here is a calculator that will help with determining the correct size pulley for the motor and cutter head.
I have purchased pulleys from Surpluscenter.com. They are well made, cast iron or aluminum and balanced.
