Best Router bit for surfacing slabs?
Forum topic by WhiskeyCreek posted 01-21-2016 08:55 PM 3281 views 0 times favorited 12 replies Add to Favorites Watch
View WhiskeyCreek's profile
WhiskeyCreek
17 posts in 1025 days
01-21-2016 08:55 PM
Topic tags/keywords: question trick tip milling joining router
What is the best type of router bit to use for surface planing slabs, without paying for specialty planing bits? Straight bit, mortising bit, rabbet bits?
-- Whiskey Creek Woodmill & Co.
12 replies so far
View MadMark's profile
MadMark
979 posts in 1325 days
#1 posted 01-21-2016 09:10 PM
None. This job calls for a planer or sander or if all else fails, a hand plane.
If you are talking about an inlay mortise, the yes, a router is the tool. For surface planing, no.
M
WhiskeyCreek
#2 posted 01-21-2016 09:16 PM
I surface plane very successfully with a router and sled all the time. I wish I had a planer and wide belt sander big enough for 11’ slabs, but that’s far fetched. I just don’t want to pay for a $200 Amana bit or comparable bits and am looking for the next best bit.
Anybody have experience with the magnate bits?
View Tennessee's profile
Tennessee
2672 posts in 2386 days
#3 posted 01-21-2016 09:22 PM
My experience is that over time, you have to realize that you have spent maybe $200-300 on bits that wear out, when for the same money you could have a good used planer off CL, or add another hundred and get a new planer.
View chrisstef's profile
chrisstef
17107 posts in 2878 days
#4 posted 01-21-2016 09:25 PM
Ive used a bowl bit with decent results but it still required a good amount of sanding. Wide slabs can be a real bear to flatten.
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1448 days
#5 posted 01-21-2016 09:25 PM
This is what I bought to do some, still haven’t had the time to use it but has good reviews.
http://www.amazon.com/gp/product/B0006B0QX4?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
If I planned on doing a lot of flattening a lot of slabs, I’d probably go with one of those expensive bit with multiple square carbide bits. Of course with the square bottom type ones I’ve heard it leaving the lines with every pass, so some people use a big bowl bottom bit.
View SASmith               's profile
SASmith
1850 posts in 2859 days
#6 posted 01-21-2016 09:28 PM
I used the 1 1/2 inch bit from here to flatten a butcher block table:
A bowl bit would work equally well, I think.
Click for details
-- Scott Smith, Southern Illinois
Gixxerjoe04
#7 posted 01-21-2016 09:30 PM
- Tennessee
Yea but he’s talking about slabs, most of which are too wide for mostly planers and def jointers, unless you have a huge bank account that is and space.
View shampeon's profile
shampeon
1775 posts in 2055 days
#8 posted 01-21-2016 09:34 PM
I’m going to use a bowl bit, like Stef sez. It’d be great to buy a 7HP 30” industrial planer to handle a 24” wide 200+ lb. slab, but for some people, that’s just not practical.
View HokieKen's profile
HokieKen
4594 posts in 1010 days
#9 posted 01-21-2016 09:53 PM
I bought this one for flattening a slab. Never got around to building a sled but I have used the bit to form half lap joints and tenons and it works great. Leaves a sharp corner and smooth finish. I’ve definitely got my $s worth out of it. If you’re doing large slabs, you might want one a little bigger though.
-- Kenny, SW VA, Go Hokies!!!
View Ger21's profile
Ger21
1074 posts in 3003 days
#10 posted 01-21-2016 11:50 PM
Any large diameter carbide tipped straight bit will work.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View AandCstyle's profile
AandCstyle
2950 posts in 2129 days
#11 posted 01-22-2016 12:18 AM
Here is a link to a jig you can use, but you may already have one. I have been satisfied with the one Magnate router bit I bought. Get the biggest diameter bit you can find because an eleven foot slab will require a lot of passes. The bottom cleaning bit Scott suggested would be a good one.
-- Art
View stan3443's profile
stan3443
300 posts in 2147 days
#12 posted 01-22-2016 01:05 AM
The Magnate bits are very good they are a true flat bottom bit most bowl bits have a 1deg angle . They go up to 2.75 dia. make shure you have the power to spin it
-- If your not supposed to have hair on your face......why does it grow their
