Using a hold-down with square dog holes
Forum topic by luthierwnc posted 01-21-2016 06:45 PM 924 views 0 times favorited 5 replies Add to Favorites Watch
View luthierwnc's profile
146 posts in 1707 days
01-21-2016 06:45 PM
Hi All,
I’m considering a project where I could see the advantage of using one or two hold-downs rather than clamping things to the edge of the top or using the dogs on the bench. I’m talking about traditional L-shaped steel units tapped into bench holes.
Trouble is: I’ve got all rectangular bench dog holes that are angled at 2 degrees towards the vise. I can’t see getting enough friction to make the thing stay put. I’d rather not drill new holes in the top.
Does anyone have ideas for the round peg in the square hole? Thanks, Skip
5 replies so far
View jdh122's profile
991 posts in 2748 days
#1 posted 01-21-2016 06:58 PM
I bet that the hold fast would hold just fine in square holes, but over time they would likely deform the holes. This guy in another forum tried it and found it to work:
-- Jeremy, in the Acadian forests
View HokieKen's profile
4653 posts in 1069 days
#2 posted 01-21-2016 07:25 PM
Are your square dogs big enough to make a blank and drill a 3/4” hole through?
-- Kenny, SW VA, Go Hokies!!!
View Mark Kornell's profile
Mark Kornell
1169 posts in 2461 days
#3 posted 01-22-2016 04:20 AM
It would be pretty easy to.drill some 3/4” holes in the benchtop where you need them for optimal holdfast placement. Likely you want the stem of the holdfast set back from the front edge anyway.
-- Mark Kornell, Kornell Wood Design
View rwe2156's profile
2834 posts in 1411 days
#4 posted 01-22-2016 12:33 PM
What Mark ^ said.
A couple strategically placed holes is probably all you need.
#5 posted 01-25-2016 02:59 AM
Looks like some new holes. Thanks guys! sh
