Need best long term idea for having Planer table smooth and glide nice
Forum topic by stoutrugby posted 01-21-2016 04:45 PM 1820 views 0 times favorited 17 replies Add to Favorites Watch
View stoutrugby's profile
stoutrugby
6 posts in 853 days
01-21-2016 04:45 PM
Topic tags/keywords: planer table top lubrication friction
I have a 20” Powermatic Planer and I wanted to know what everyone’s thoughts are on the best coating for long term lubrication on the table. I’ve heard wax is bad due to friction/heat build up and then it slows parts down.
I know GlideCote formally knows as TopCote works well, but I wanted to see if there is something else out there that doesn’t need to be applied as often.
Thanks for any input,
Tracy
17 replies so far
View MadMark's profile
MadMark
979 posts in 1450 days
#1 posted 01-21-2016 05:57 PM
Johnson’s Paste Wax is what I use on everything. You want to be careful with any silicon based lube as this will poison the surface againt finishing. Your poly will convert to orange peel at the slightest trace. Wax works and doesn’t contaminate finishing.
M
View HokieKen's profile
HokieKen
4989 posts in 1135 days
#2 posted 01-21-2016 06:29 PM
Put me down for Johnson’s too. I put formica on my planer tables but I have paste wax on my table saw and bandsaw tables and have never had any issue with friction. Quite the opposite.
-- Kenny, SW VA, Go Hokies!!!
View MrUnix's profile
MrUnix
6706 posts in 2196 days
#3 posted 01-21-2016 06:38 PM
have a 20” Powermatic Planer and I wanted to know what everyone s thoughts are on the best coating for long term lubrication on the table. I’ve heard wax is bad due to friction/heat build up and then it slows parts down.
- stoutrugby
Where did you hear that?!? The most common treatment is paste wax. And the manual for the PM 20 inch planer even says:
The table should be kept clean and free of rust. Some users prefer a paste wax coating. Another option is talcum powder applied with a blackboard eraser rubbed in vigorously once a week; this will fill casting pores and form a moisture barrier.
I’ve used paste wax for decades, along with keeping the table surfaces covered when not in use. Never had a rust problem even in the worst humidity/conditions – and it makes stock glide over them easier, not harder, and I’ve certainly never experienced it to cause friction/heat!
View AandCstyle's profile
AandCstyle
3052 posts in 2254 days
#4 posted 01-22-2016 12:33 AM
Tracy, another happy Johnson’s paste wax user here. You could also look at Boeshield T-9.
-- Art
View builtinbkyn's profile
builtinbkyn
2273 posts in 937 days
#5 posted 01-22-2016 12:36 AM
Wax. Oh, I see it’s already been mentioned ;)
-- Bill, Yo!......in Brooklyn & Steel City :)
View gfadvm's profile
gfadvm
14940 posts in 2687 days
#6 posted 01-22-2016 01:47 AM
I use paste wax on my big planer and it works great.
Never heard of the talcum powder thing. Interesting. It sure makes it easier to pull my boots on!
View JBrow's profile
JBrow
1354 posts in 917 days
#7 posted 01-22-2016 01:57 AM
stoutrugby,
I use Minwax paste wax on my Woodmaster planer bed. I have had no problems other than having to re-apply wax on a regular basis.
Since I do not like applying the wax (just too much trouble), I will be giving serious thought to a planer bed upgrade to my Woodmaster 12” planer. Woodmaster Tools offers a polypropolene polymer surface that is 1/2-inch thick and mounts on top of their planer beds. Woodmaster claims this planer bed accessory reduces friction by 70%, increases roller life, and increases feed motor performance. It is supplied with two poly guide rails and mounting hardware. They want $289 for this bed cover for their 25” wide planer. This product is at:
http://www.woodmastertools.com/NS/accessdetail.cfm?PID=60
I did a quick search of the internet and found a .500” x 24” x 48” sheet of Natural Polypropylene Stress Relieved Sheet for $59 from Ridout Plastics Co. Inc. They also offer a straight line cut of the sheet for an additional charge of $18. This company is found at:
http://www.eplastics.com/Plastic/polypropylene_sheet/PRONAT0-500SR24X48
Since I am not yet ready to upgrade, I have not contacted Woodmaster to determine why they are charging such a premium. Nor do I know whether Woodmaster’s product and that of Ridout Plastic is the same material. There may be more to this slick surface than meets the eye. But at this time, ending the routine of regularly waxing the planer bed is pretty attractive to me.
gfadvm
#8 posted 01-22-2016 02:06 AM
JBrow, I wax my Woodmaster with a piece of Scotch Brite pad rubbed in paste wax and do not buff it off. This is really quick and has never caused a problem with the boards being planed.
View TheFridge's profile
TheFridge
9454 posts in 1483 days
#9 posted 01-22-2016 02:32 AM
I leave a rag in the JPW can. Occasionally, I actually have to turn the crank on the planer to wax the bed. Aside from that. 2-5 minutes a week maybe for upkeep. On all tools.
JBrow
#10 posted 01-22-2016 03:04 AM
gfadvm,
Thanks for the tip. I’ll give the Scotch Brite pad try. I assume you use the Scotch Brite pad on your other cast iron?
gfadvm
#11 posted 01-22-2016 03:52 AM
Yep, I use the same process on all the cast iron surfaces. Leaving the wax rather than buffing makes this quick and easy. They will hold a lot of wax and they are abrasive enough to remove sap and light surface rust. I leave a square of it in the wax can.
Edit: I use the grey pads or the green ones (don’t think that’s important though). They will get black and nasty but just keep using them.
stoutrugby
6 posts in 853 days
#12 posted 01-22-2016 05:27 PM
Thanks to everyone with the helpful insight. I do have to tell you the Bostik GlideCote is nice, but I’ll go buy some of the Johnson paste wax and give it a fair shake before committing.
Thanks again and have a great weekend.
View ErnestP's profile
ErnestP
14 posts in 908 days
#13 posted 01-23-2016 01:26 AM
If your intent is less effort, get a can of Glide Coat/Dri-Glide, etc.
It is a teflon-based spray, on a super volatile carrier.
Spray, polish briefly and you’re good to go, for quite awhile.
It wears really well, about 3-4x a wax finish (imo).
It is crazy expensive, at about $20 a can, but it goes a long way.
Otherwise, my favorite wax brand is Trewax (I think it lasts longer).
It can be hard to find, though Brewax is a close second.
The plus side to Johnson’s, you can find anywhere…cheap.
Basically, any wax will serve, given regular use.
The caution on the use of silicon-based solutions, is also ‘spot-on’.
They can contaminate the wood, requiring extra effort to avoid finish problems.
So, with wax and teflon spray available, I would steer clear of the possibility.
Ern
View AlaskaGuy's profile (online now)
AlaskaGuy
4133 posts in 2306 days
#14 posted 01-23-2016 03:47 AM
That has to be one of the most WRONG things I heard in a long time.
View JoeinGa's profile
JoeinGa
7736 posts in 2004 days
#15 posted 01-23-2016 01:03 PM
Hmmmm, 14 answers and no one has mentioned Johnsons Paste Wax yet? Geeze, I thought everybody used wax on their tools.
