First step in painting raw maple....
Forum topic by patcollins posted 01-20-2016 11:16 PM 863 views 0 times favorited 15 replies Add to Favorites Watch
View patcollins's profile
patcollins
1685 posts in 2859 days
01-20-2016 11:16 PM
I know it pains me to paint any hardwood, but my cabinets were in poor shape and it was paint the bases or tear them out.
I got new raised panel maple doors from www.rawdoors.net (and they are beautiful btw) and I was debating if I should use a sanding sealer on them first or a water based primer or….what for the best results.
15 replies so far
View conifur's profile
conifur
955 posts in 1145 days
#1 posted 01-20-2016 11:21 PM
What type of cabinet and where??? If the new doors are beautiful, just paint the frames and leave the dooors in a natural wood finish, it is a nice look, with maple doors I would do the cabinets in a darker greenish gray depending on room color.
View Ger21's profile
Ger21
1074 posts in 3125 days
#2 posted 01-20-2016 11:22 PM
Use the appropriate primer for the paint you’ll be using.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
patcollins
#3 posted 01-20-2016 11:34 PM
- conifur
Kitchen, The cabinets were this awful darkish dirty banged up oak from 1976 and the doors on them were extremely cheap. After much prep I painted them a light gray color that I am very happy with.
conifur
#4 posted 01-20-2016 11:37 PM
conifur
#5 posted 01-20-2016 11:42 PM
I had a client that redid kitchen cabinets by painting them, the paint did not hold up around the pulls after about 2 years.
conifur
#6 posted 01-20-2016 11:43 PM
I cant find the exact pics I want.
patcollins
#7 posted 01-21-2016 12:20 AM
- conifur
I have done a few things to mitigate this from happening. I am using drawer pulls that ll but prevent you from touching the drawer faces. I also used Sherwin Williams Pro Classic waterborn alkyd paint which holds up much better than a latex.
Here is a picture of what I have so far, I get new counter tops this friday.
patcollins
#8 posted 01-21-2016 12:21 AM
House was quite a fixer-upper when I bought it, this is what I started with.
conifur
#9 posted 01-21-2016 12:31 AM
What ever to your taste, I would have left the doors unpainted and just painted the face frames, but its is your kitchen and taste, differently an improvement.
patcollins
#10 posted 01-21-2016 12:52 AM
- conifur
I sort of cheaped out by not replacing the drawer fronts. Somewhat trying to prove a point about the cost to remodel a kitchen, to myself at least. I have a coworker that spent $100k for a kitchen remodel…..
conifur
#11 posted 01-21-2016 02:37 AM
Pat that was I did for a living the last 20 years b4 retiring, residential remodeling, easily done if you are not realistic. I did a kitchen, they wanted a commercial grade gas stove, now the seller of the stove did the install, so about a year later I get a call, from the new owner of the house, the stove does not work, so as a courtesy and possibly a new client I stopped by, sure enough gas stove does not work, and no smell of gas when I tried to ignite a burner, looked in back, gas line is still capped off. First the installer goofed up, but more importantly the client that wanted it, never tried to use it. True story!!!
View TheFridge's profile
TheFridge
9444 posts in 1480 days
#12 posted 01-21-2016 02:41 AM
I painted my kitchen cabinets. 2-3 coats of kilz and 2-3 coats of latex enamel. Would’ve used oil based if I knew better at the time. Worked out great. 5 years and no probs.
patcollins
#13 posted 01-21-2016 03:09 AM
- conifur
LOL
I have heard that most people that just have to have commercial stoves rarely even eat at home. I guess they are a status symbol.
conifur
#14 posted 01-21-2016 03:46 AM
@patcollins, it sure was there just for status!!
View dhazelton's profile
dhazelton
2766 posts in 2290 days
#15 posted 01-21-2016 01:50 PM
- conifur
I like the look. Those cabinets are waaaaaaaaaay too dark for a small kitchen. Painting just the carcasses and leaving the doors would look goofy to me.
I’ve painted a lot of kitchens. As long as things are sanded well and you use a quality paint you should never have a problem. I always make sure to use a liquid sandpaper type product on old varnished wood as a wipe down after sanding. That also helps remove any grease from the stove that may be on the cabinets.
