to use MDO or not??
Forum topic by siouxdawgs0409 posted 01-29-2010 09:39 PM 1394 views 0 times favorited 4 replies Add to Favorites Watch
View siouxdawgs0409's profile
siouxdawgs0409
107 posts in 2997 days
01-29-2010 09:39 PM
I am curious if there is and good substitute for 1/2 inch MDO? It is to be used on an indoor bench cabinet. Is there any other alternative that might be a little cheaper and easier to find? Seems to me a good quality birch plywood would work, just would not have quite the smooth finish and would be lighter in color. Maybe a little lighter weight with the birch as well. Cost is probably about the same. MDF would probably not work as I would like to have the screw capabilty that MDO and plywood offer. Any input?
View bigike's profile
bigike
4053 posts in 3191 days
#1 posted 01-29-2010 09:45 PM
u can always get screws that’s made for mdf, MDO your gonna have to paint. I would go with the ply.
Rick Dennington
5692 posts in 3097 days
#2 posted 01-29-2010 09:55 PM
Greetings descout:....I see no reason why the MDO won’t work for your need. As you know, MDO is plywood with paper on both sides. I use it a lot. Not sure what you mean by a bench cabinet. Are you talking about a cabinet that will sit on a bench? If so, yes it will work for any cabinet, but to me personally, I think 1/2” is a little thin for a cabinet (of course I like 3/4” myself), but it will work. MDF would be cheaper, of course, and work ok. Hey… it’s your cabinet…. make it any way you want to with the materials you have on hand…..later.
siouxdawgs0409
#3 posted 01-29-2010 11:11 PM
It is just a cabinet that is built under a bench. 1/2 inch should work since it has a solid hardwood frame. Where have you found the MDO? I have called local lumber yards and it seems no one carries the stuff.
View leroy49's profile
leroy49
19 posts in 3332 days
#4 posted 01-29-2010 11:26 PM
I have seen MDO at Menard’s. As far as the bench goes I think the birch ply would work good. I would probably go with the 3/4” ply or MDO.
