How to put a hinge on this box?
Forum topic by mahdee posted 01-19-2016 08:19 PM 719 views 0 times favorited 4 replies Add to Favorites Watch
View mahdee's profile
mahdee
3844 posts in 1673 days
01-19-2016 08:19 PM
Topic tags/keywords: question
I am trying to figure out how to put a hinge on this box. It is made from some sort of molding that is 3/4” thick and as you can see, it has curve which limits the dept of screw. I think a 1-3/4” (open) hing might work as long as the screw holes on the leaves are not too close to the hinge itself but few hours of search have been in vain so far. I like the rail hinges as well but the price deterred me from going that route. Any ideas as to how I should tackle this is much appreciated.
I had no idea how expensive brass hinges run for.
-- earthartandfoods.com
View Benvolio's profile
Benvolio
148 posts in 1837 days
#1 posted 01-19-2016 08:31 PM
if it was me, I’d get some chunky brass leaved hinges – maybe brusso, chisel out a rebate with a flat back to accept the hinge, then contour the face of the brass with a rat tail file to follow the lines of the wood.
-- Ben, England.
mahdee
#2 posted 01-19-2016 08:50 PM
Thanks Ben,
I was planning to put the hinges on top and didn’t want the screws to come through the lip at the bottom.
View JADobson's profile
JADobson
968 posts in 2017 days
#3 posted 01-19-2016 09:56 PM
I wonder if you could cut mortises for the hinges like normal but epoxy them in place rather than screw them down. You could cut off the heads of the screws and epoxy them in place as well.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany
mahdee
#4 posted 01-20-2016 01:26 AM
James, excellent idea. Thanks
