Table Apron/Skirt to Leg Joint
« back to Joinery forum
Forum topic by langski93 posted 01-19-2016 01:46 PM 1631 views 0 times favorited 5 replies Add to Favorites Watch
View langski93's profile
langski93
111 posts in 3554 days
01-19-2016 01:46 PM
Topic tags/keywords: joining sliding dovetail mortice and tenon table leg connection attachment
Except for cutting rough lumber to length, all work is being done with hand tools.
I am dimensioning material for a dining room table. It will be 78” in length and 30” to top of table. The legs will be tapered from a 3” square billet.
The top will be a heavy piece of walnut made from 3 boards. The width of the top will net out at least 38” and possible as wide as 40”. I have not worked out all of the dimensions, but the apron will be 3.5” to 4” wide.
I am trying to decide if I should use M+T joint or sliding dovetail to connect the apron to the legs. I see sliding dovetail used on smaller tables and question if the scale of this piece is too large for that connection. I am concerned about the downward wedging action of the dovetail on the leg. In theory, if left unglued, the joint has the potential to be freed up if/when the table is ever moved. M+T joints, pinned or not are fixed.
All thoughts, suggestions and alternatives are appreciated.
Misc.
Does anyone else make a distinction between a table apron and a skirt? I saw a diagram where the width piece was labelled as a skirt and the longitudinal piece was labelled an apron. I just refer to both as an an apron.
-- Langski, New Hampshire
5 replies so far
View bondogaposis's profile
bondogaposis
4931 posts in 2472 days
#1 posted 01-19-2016 01:50 PM
I’d go w/ M&T. It is tried and true, larger glue surface.
-- Bondo Gaposis
5072 posts in 2614 days
#2 posted 01-19-2016 03:59 PM
What Bondo said^^^^^^^
View AlaskaGuy's profile
AlaskaGuy
4371 posts in 2430 days
#3 posted 01-19-2016 05:51 PM
What Fred Hargis said.
http://diy.stackexchange.com/questions/35802/can-mortise-and-tenon-joints-be-strong-without-glue
Just something I read. I have no practical experience.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2490 days
#4 posted 01-19-2016 06:26 PM
I’d go with the haunched M&T, drawbored. I’ve only built two tables ever, but this approach has worked out very well for me. I don’t have clamps long enough for the sides, so apply a little glue to the joint, whack in the pegs, and move on, no clamps required, and a little extra peace of mind.
Edit : Not sure what the location this is ending up in is like, but you have made sure that you can get a table of this size, with non-removable legs, into the destination, correct?
langski93
#5 posted 01-20-2016 12:58 AM
Thanks everyone. Alaskaguy I never considered the lateral split between joints like the diagram, but I can see it happening with the illustration you provided. My original concern was more of lengthwise split. Yours is just another reason to avoid the sliding dovetail.
I will be using an M&T with draw boarded pins based on the feedback.
BinghamtonEd, yes it will go through the two doorways I need to pass. Measuring that was one of the first things I did. When I was first married I bought a couch, dragged it home and then dragged it back after I could not get it up a set of stairs. The good ol’days
