| Forum topic by descout | posted 1205 days ago | 927 views | 0 times favorited | 13 replies | ![]() |
1205 days ago |
Ok so I am fairly new to all this woodworking and never realized how many ways there are to finish one piece of wood! I am working with walnut knife block and I am looking to finish it. I have the time and am in no rush so I think I am going to go with dark walnut danish oil, then an amber shellac followed by a topcoat. Would something like Arm R seal do the trick? I am looking for suggestions on the top coat. I have used Arm R Seal before and had great results, just never used on top of the oil and shellac. What do you guys think? |
13 replies so far
#1 posted 1205 days ago |
try it on piece of scrap first. -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
#2 posted 1205 days ago |
I used shellac on top of the danish oil (let the oil dry really well first). Worked great. didn’t try varnish on top though. Don’t see why it could be an issue. |
#3 posted 1205 days ago |
There is nothing wrong with this finishing routine. Oil, with a shellac sealer, followed by a wiping varnish topcoat is a common finishing schedule. As Bigike said do it on some scrap first to see if this will give you the finish that you want. If you are using the Watco product it contains raw linseed oil (not boiled linseed oil) which has a recommended cure time of 3 days. I would give the base application of the danish oil plenty of cure time as Mtkate suggested. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#4 posted 1205 days ago |
FWIW I allow any finish that contains BLO to cure at least 5 days in a heated or air conditioned shop before applying any varnish/poly/lacquer finish over it. -- Only the Shadow knows.................... |
#5 posted 1205 days ago |
Walnut is absolutely beautiful….its my fav. I just rub tung oil in it. Dale -- Dale, Michigan, vandehberg@att.net....sharp objects scare me.....my wife scares me too. |
#6 posted 1204 days ago |
Will a lacquer over the top of the shellac work? I know the waxed shellac with not agree with the polyurethane but I am thinking lacquer would work for the top coat. |
#7 posted 1204 days ago |
I am with UncleSnail on this one. Just use Tung Oil and let the wood come through. |
#8 posted 1202 days ago |
BLO, a tung oil finish (not raw tung oil), wiping varnish. ANYTHING BUT POLY. Do you get the feeling that I don’t use poly unless I’m forced to? -- bill@magraphics.us |
#9 posted 1202 days ago |
I’m with Bill on this one. Shy away from poly if at all possible. Once moisture gets behind it it looks terrible, and its a pain in the a#$ to refinish. I’d use blo, shellac, and either leave it at that or use a wiping varnish instead of a poly. -- Julian, Park Forest, IL |
#10 posted 1202 days ago |
Do not use Poly for anything other than a Bar top, it takes away from the beauty of the wood. I agree with the Tung Oil and maybe a few coats of paste wax for added protection. Its all about the wood, isn’t it? -- It's not the breaths U take but the moments that take your breath away !! |
#11 posted 1202 days ago |
I am working with some walnut right now as well. I typically use two coats Cabot’s Tung Oil Finish, because it looks good and cures faster than pure tung oil, then shellac because I like how it adds depth to the grain then topcoat with lacquer for added protection. I haven’t had any problems with it so far so until I do it’s a standard for me. Good Luck!!! -- Joe Truehart - The Craftsmans Woodshop |
#12 posted 1202 days ago |
I make my own Danish Oil Blend 1/3 BLO, 1/3 Mineral Spirits, 1/3 varnish and I’ll put maybe 1/2 a cap of Japan Drier in a cup of finish. it hardens up overnight. You cannot save any of the finish that has the Japan Drier put in it. I put it on and after an hour or so I put another coat on again, I also sand it with 400 grit and the slurry pf walnut dust and oil fills the pores. After it dries is cut the slurry off and try not to pull it out of the pores. Giving it a second day might help on that process. I use a scraper and cut across grain at a 45 deg angle to cut it off. -- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware karson_morrison@bigfoot.com † |
#13 posted 1192 days ago |
All great advise. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15748 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
