'In _____ style' or roll your own?
Forum topic by MadMark posted 01-18-2016 06:43 PM 958 views 0 times favorited 25 replies Add to Favorites Watch
View MadMark's profile
MadMark
979 posts in 1421 days
01-18-2016 06:43 PM
Topic tags/keywords: question joining sanding milling traditional modern design plans
Many here do excellent work following existing designs. For me, I’d rather wind up with a pile of kindling of my own design rather than than a perfect copy of someone elses work.
Do you: Work from existing plans?
Or: Roll your own?
Discuss!
M
25 replies so far
View conifur's profile
conifur
955 posts in 1119 days
#1 posted 01-18-2016 06:54 PM
Both and sometimes modify an existing one.
View jmartel's profile
jmartel
7808 posts in 2118 days
#2 posted 01-18-2016 06:58 PM
I usually do google searches and searches on here for similar things, then use them to create my own designs. I’ve built some things off of modified plans from magazines/books though.
View JoeinGa's profile
JoeinGa
7735 posts in 1975 days
#3 posted 01-18-2016 07:19 PM
I’m in the “Roll your own” crowd. I never make any sort of production runs for multiple items, and I absolutely HATE to try and follow printed Plans. Years ago, when I ordered a few plans, NOTHING seemed to fit when I cut from plan measurements. So I generally start with an idea in my head, some rough dimensions for the piece (especially if it has to fit inside something already constructed) and start cutting.
Pretty much everything I do is never an exact copy of a previous piece.
View Mosquito's profile
Mosquito
9280 posts in 2260 days
#4 posted 01-18-2016 07:26 PM
I have never built a project from plans made by someone else. I’ve used existing plans as a springboard to create my own based on it, but that’s the closest I get.
I also don’t generally stick to a specific style either
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View ste6168's profile
ste6168
255 posts in 1139 days
#5 posted 01-18-2016 07:32 PM
I agree with everyone else. Never built anything from existing plans, but I have never made a true, what i would consider “artistic” piece. All of my stuff is modeled on ideas and other pieces I have seen elsewhere.
Two examples are below, neither were my original idea, but both were built from my plans.
View bandit571's profile
bandit571
19753 posts in 2651 days
#6 posted 01-18-2016 07:38 PM
Usually, the Single Brain Cell Sketch Up comes up with it’s own designs, and “takes” on other designs…
Just depends on the wood I have in the shop..
View builtinbkyn's profile (online now)
builtinbkyn
2205 posts in 908 days
#7 posted 01-18-2016 07:40 PM
Well if a pile of kindling is the end result of doing your own thing, maybe it would be a good idea to learn from doing something that’s been done before and could be used as an example of what to do vs not to do.
-- Bill, Yo!......in Brooklyn & Steel City :)
View Nic's profile
Nic
65 posts in 1115 days
#8 posted 01-18-2016 07:47 PM
While I’m not too experienced of a woodworker, on of my favorite parts of the process is designing something unique to make. Conceptualizing something you know will be beautiful (to yourself, at least) is as rewarding as completing the project in my opinion. I’ll wake up one morning with an idea and draw it during the school day and I ultimately end up with something I’m excited to build one day. Even with an existing style I like to draw my own plans, edit the look a bit, and mix it up. I’m not opposed to using plans, but I just don’t for now. Maybe if I tackle some intense and accurate reproduction I’ll use some, but for now? Not a chance.
-- Third time's the charm, right?
MadMark
#9 posted 01-18-2016 07:49 PM
Like you’ve never mis cut or wound up cutting miters backward? With the Incra I make very precise errors. If I cut something an inch short I can take solice in that it is precisely 1.000” short.
Prototypes occasionally wind up in the kindling (or at least in the offcut) pile.
Even a simple box may take several prototypes to get ‘just’ right.
But in the end my project is mine – warts and all.
M
View HokieKen's profile (online now)
HokieKen
4747 posts in 1106 days
#10 posted 01-18-2016 07:51 PM
Definitely roll my own. However it’s rarely, if ever, entirely conceived in my own mind. There are usually several sources of inspiration that I “make my own”.
-- Kenny, SW VA, Go Hokies!!!
View JayT's profile (online now)
JayT
5589 posts in 2179 days
#11 posted 01-18-2016 08:15 PM
I have never built a project from plans made by someone else. I ve used existing plans as a springboard to create my own based on it, but that s the closest I get.
- Mosquito
Definitely roll my own. However it s rarely, if ever, entirely conceived in my own mind. There are usually several sources of inspiration that I “make my own”.
- HokieKen
Some combination of these. I don’t build from plans, but may use plans or pieces I’ve seen as inspiration for creating my own piece.
I like the creative side of woodworking. Slavishly following someone else’s plans isn’t being creative, it’s being re-creative.
View BurlyBob's profile
BurlyBob
5417 posts in 2233 days
#12 posted 01-20-2016 01:11 AM
I’m pretty much in that roll my own crowd. Some of the designs/patterns seem to be a little over the top with details.
View TheFridge's profile
TheFridge
9249 posts in 1454 days
#13 posted 01-20-2016 01:15 AM
I steal plans as much as possible. Let someone else do the work.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1144 days
#14 posted 01-20-2016 01:26 AM
I build from plans. Sometimes after building a prototype from a plan I will then modify the next version slightly.
I don’t consider myself to be artistically inclined.
bandit571
#15 posted 01-20-2016 02:48 AM
- TheFridge
LOL….and that is why I’ve never drawn plans for the stuff I build…...LOL.
