ALIGNING BLADE N FENCE RIDGID 4511
Forum topic by duke59 posted 01-28-2010 05:37 PM 874 views 0 times favorited 4 replies Add to Favorites Watch
View duke59's profile
duke59
3 posts in 3012 days
01-28-2010 05:37 PM
GOT SAW ALL PUT TOGETHER NOW ITS TIME TO ALIGN. CAN THIS BE DONE WITH THE SQUARE,OR DO I HAVE TO SPEND MORE$$ ON EXPENSIVE GUAGES?
-- Duke from ill
117062 posts in 3541 days
#1 posted 01-28-2010 05:47 PM
You can measure from the front and back of the blade off the miter slot. You can use any thing from a combination square to a feeler gauge,
View woodworm's profile
woodworm
14462 posts in 3555 days
#2 posted 01-28-2010 05:58 PM
If the blade is parallel to the miter slot, you still need to check its also parallel to the fence at a few positions. If its parallel in a position but slightly off in another position, probably the fence’s rail that needs adjustment.
-- masrol, kuala lumpur, MY.
View MarkwithaK's profile
MarkwithaK
370 posts in 3142 days
#3 posted 01-28-2010 06:09 PM
I used a combination square got it squared. I do have a dial indicator I got from HF for $10 but I haven’t had need to use it yet.
-- If at first you don't succeed then maybe skydiving isn't for you.
View funchuck's profile
funchuck
119 posts in 3022 days
#4 posted 01-28-2010 11:49 PM
I used a dial indicator attached to a wooden jig, but a friend of mine told me an easy way, he clamped a straightedge onto his miter gauge.
-- Charles from California
