Cutting 2 mm (5/64") strips on TS - vacuum powered
Forum topic by niki posted 11-10-2007 09:04 PM 3132 views 4 times favorited 11 replies Add to Favorites Watch
View niki's profile
niki
426 posts in 3988 days
11-10-2007 09:04 PM
Good day
I would like to share with you an idea that was “sitting” in my head for long time and yesterday, I made it.
The title is “2 mm” (5/64”) because I tested it by cutting 2mm strips but, it can be any thickness of strips….even less…
So…the sled is an 3/4” Melamine board 36” long and 8” wide but, you choose yours.
I drilled 3/8” “Vacuum holes” but first I drilled 1/4” as a pilot hole (easier to control the drill) and than went with the 3/8” drill bit to the end of the drill length
I drilled the holes at 4” intervals but I think that the more holes, the better (say, every 2½”~3”) even though, I did not have any problems with the vacuum pressure.
I drilled 3/4” hole dia at the “end of the drill line”
The “Box” can be made of anything…I made it from pieces of chip-board and Melamine (that’s what I found in the attic)
The Shop-vac is my converted home-vac that I used on “Minimum” power.
I strongly recommend to use a “Feather board” to hold the work and sled firmly to the fence before entering the blade…especially on long boards
You can add a push handle…I just use the “box” to push the sled.
Regards
niki
11 replies so far
View Dan'um Style's profile
Dan'um Style
14171 posts in 3891 days
#1 posted 11-10-2007 09:11 PM
cool idea
35100 posts in 4309 days
#2 posted 11-10-2007 10:46 PM
Great idea Niki. And it keeps you from having to move the fence each time.
View mot's profile
mot
4911 posts in 3945 days
#3 posted 11-10-2007 11:44 PM
That would work pretty good if you had to cut a load of edge banding. Nice, Niki.
View gizmodyne's profile
gizmodyne
1771 posts in 3998 days
#4 posted 11-11-2007 12:12 AM
Interesting. What’s the verdict in the end? Will you use it.
View niki's profile
niki
#5 posted 11-11-2007 09:46 AM
Thank you so much
Gizmodyne
I don’t have many machines…actually, just a table saw and router table but, each of the jigs that I make, is used again and again almost on every project.
Right now, I’m not working on anything (too cold in the garage) but I’m making some jigs that are on my “wish list” at the time that I was working on a project, kind of, “if I had this jig, it would be easier and safer”...
Regards
niki
View ben's profile
ben
158 posts in 3779 days
#6 posted 11-11-2007 03:08 PM
Niki,
This is a shining example of genius by simplicity.
Do your jigs take up more space in your shop than your tools? :-)
-b
View Thos. Angle's profile
Thos. Angle
4445 posts in 3871 days
#7 posted 11-12-2007 05:09 AM
My heavens, Niki, I’m always impressed with your ingenuity. Self reliance indeed. Keep ‘em coming.
#8 posted 11-12-2007 05:11 AM
What tools he’s got a table saw and a drill. Thats why he needs all the jigs.
View Digitalwoodshop's profile
Digitalwoodshop
4 posts in 3298 days
#9 posted 02-13-2009 06:53 PM
Excellent Project !!!! I was looking for ideas to make a Vacuum Sled to hold thin Plastic to run through my CarveWright Carving machine to make small name tags from sheet stock. This is the right concept….
Thanks,
AL
-- www.poconodigitalwoodshop.com
View PurpLev's profile
PurpLev
8534 posts in 3557 days
#10 posted 02-13-2009 08:07 PM
nicely done, great idea!
View bendisplays's profile
bendisplays
40 posts in 3309 days
#11 posted 02-15-2009 08:22 PM
Niki,
Thats a nice idea. Thank you for sharing it.
Ben
