Question re: powering in-wing router from 220V saw supply
Forum topic by theo posted 01-28-2010 02:40 AM 2984 views 0 times favorited 9 replies Add to Favorites Watch
View theo's profile
theo
6 posts in 3846 days
01-28-2010 02:40 AM
Topic tags/keywords: router electrical
I’m looking for advice on home to most easily power the router I have in my unisaw extension wing.
The 220V outlet I have is wired with 10/3 to the outlet, 12/3 to the saw so, since there’s no neutral there (correct?) I don’t believe that I can pull 120V off before the saw (I have hot-hot-ground not hot-neutral-ground correct?). Does this sound correct? My electrical knowledge is a bit rusty when you get larger than BJT’s.
Since this isn’t going to work, how does everyone manage the extra cord? I know I can simply run the cord, but was hoping for something more elegant (I think I should have run 10/4, then a 12/4 extension cord, but that’s not financially feasible at the moment).
So, how do others manage this?
Thanks for the input!
9 replies so far
View lew's profile
lew
12495 posts in 3991 days
#1 posted 01-28-2010 02:45 AM
10/3 and 12/3- is this “with ground”? In other words, do you have 4 wires? If so, then one of them is probably neutral. 10/3 with ground is usually Red, Black, White and bare. The white should be the neutral.
View sIKE's profile
sIKE
1271 posts in 3990 days
#2 posted 01-28-2010 02:52 AM
Not that this helps now, but was how I handled it….
TopamaxSurvivor
18423 posts in 3911 days
#3 posted 01-28-2010 03:15 AM
If you have 2 hots and no neutral you are correct. I doubt if your cord cap and plug have 4 connections. If they have 3, you have 2 hots and a ground.
View theo's profile
theo
#4 posted 01-28-2010 04:00 PM
sIKE – I’d love to take advantage of your solution, but I’m thinking it may be a bit challenging currently (I’m not really in a position to rip up my shop/garage floor, unfortunately)
lew – There is definitely no uninsulated wire, the extension cord is terminated with L6-20 twist locks, and the cable that I made the cord from is what’s pictured below:
12/3 extension cord
So, from what TopamaxSurvivor says, I have no neutral. I’m definitely wishing I’d had the foresight to run 10/4 and 12/4…
So, given that I didn’t do a ton of thinking when I wired this, I guess I’m hoping that someone has some brilliant/elegant way of handling the extra cord for the router (preferably one that doesn’t involve significant construction – see sIKE’s enviable solution).
Thanks for the input so far!
View lew's profile
lew
#5 posted 01-28-2010 04:49 PM
Sorry,
I thought you were talking about the “house side” wiring that came to the female receptacle. If the receptacle is wired with the Red, Black, White, bare (ground), you could maybe tap into the White, Black, Ground for 120v and wire in a separate receptacle for the router.
Lew
View MarkwithaK's profile
MarkwithaK
370 posts in 3414 days
#6 posted 01-28-2010 06:17 PM
Many times when I’m working on a roof top unit and need a 120VAC connection I have used the female end of an extension cord with alligator clips to go from one leg on the 240 disconnect and the other to ground. I know it works in a pinch but not sure I would trust it long term
-- If at first you don't succeed then maybe skydiving isn't for you.
View Steven Naslund's profile
Steven Naslund
12 posts in 3737 days
#7 posted 01-28-2010 07:52 PM
1. An L6-20 is two hots and a ground. No Neutral so you can’t run 120VAC. Using one hot and one ground as suggested above will provide 120V but the problem is that you don’t have an additional ground left. This violates code and is unsafe since the purpose of the ground is to provide an alternate return path. It can compromise your entire building grounding system to do this because power applied to the ground will appear system wide. Bad idea. This is a technicians trick used for temporary purcposes only. It appears that you have another outlet opening available in your box, you could pull a neutral in or just add another circuit.
You may also want to check if your router can handle 240V, alot of tools can now handle either voltage if the right cord set is put on it.
-- Steven Naslund, Chicago IL
View sIKE's profile
sIKE
#8 posted 02-01-2010 09:46 PM
Oh and the 220V side is 10/4. I have the neutral capped off at this point as there is no need for it. If I had to do it again, I would of gone with much bigger PVC as a conduit to enable me to pull more down if I ever needed.
TopamaxSurvivor
#9 posted 02-02-2010 12:49 AM
It is good for 30 amps, that should be plenty, #12 would probably have been fine at 20 amps.
