Theory: Dehumidifier + green wood = good wood
Forum topic by Zuki posted 01-28-2010 12:57 AM 9262 views 1 time favorited 18 replies Add to Favorites Watch
View Zuki's profile
Zuki
1404 posts in 3948 days
01-28-2010 12:57 AM
Topic tags/keywords: zuki dehumidifier
I was thinking. Could a dehumidifier be used to lower the moisture content in wood.
My theory:
- Built a small rectangular frame (large enough to put in a home dehumidifier)
- Cover the frame in plastic leaving a flap on each end to give access to the interior
- Put the dehumidifier in one end
- Stack the wood in through the other end
- Lower the flaps
- Turn on the dehumidifier
- Wait
I’m guessing that this would be a more aggressive way of removing moisture, however if it ran for an hour or two every day for a week . . . one should be left with usable wood.
What do you think?
-- BLOG - http://www.colorfulcanary.com/search/label/Zuki
18 replies so far
View Dan'um Style's profile
Dan'um Style
14171 posts in 3854 days
#1 posted 01-28-2010 01:00 AM
yep … it would work
View Russel's profile
Russel
2199 posts in 3810 days
#2 posted 01-28-2010 01:04 AM
Interesting idea. I might be concerned about the wood drying evenly. Would the wood closest to the dehumidifier be drier than that furthest away?
View Zuki's profile
Zuki
#3 posted 01-28-2010 01:08 AM
Rotating, flipping and restacking the wood could also be incorporated into the equation.
Of course the wood would be stickered (?) . . . separated by small strips.
View PaulfromVictor's profile
PaulfromVictor
228 posts in 3217 days
#4 posted 01-28-2010 01:12 AM
I think that just a little warmth and good air circulation would work better than making the air drier. I have never actually dried wood, but I have worked with plenty of air dried wood. People that are good at it have it down to a science. I don’t recall ever reading about a dehumidifier being included as part of the equation.
View Tim Dahn's profile
Tim Dahn
1562 posts in 3436 days
#5 posted 01-28-2010 01:14 AM
You probably want to investigate to what humidity level the dehumidifier cycles, it may not be low enough.
View Zuki's profile
Zuki
#6 posted 01-28-2010 01:19 AM
Good point Tim. Our lowest setting was 45%, however there is an override that will allow it to run much lower.
View Rasta's profile
Rasta
120 posts in 3313 days
#7 posted 01-28-2010 01:40 AM
I read an article about a home built kiln like this possibly Wood magazine? Try theirr website.
-- Roscoe in Iowa
View bsherman's profile
bsherman
76 posts in 3399 days
#8 posted 01-28-2010 05:08 AM
Are dehumidifiers expensive to run? (Like air conditioners?) If so I wonder how cost effective that would be
-- Brian
View GFYS's profile
GFYS
711 posts in 3342 days
#9 posted 01-28-2010 05:20 AM
Not only would work…does work. Daren has a plan for a small dehumidifying kiln on the Woodworkers Forum
http://www.woodworkingtalk.com/f23/small-wood-drying-kiln-plans-dry-your-own-lumber-3103/index2/
He is also a member of LJ
View alby's profile
alby
8 posts in 2939 days
#10 posted 01-28-2010 05:32 AM
zuki
Yes a dehumidifier does work but you have to be carefull.
- The ends of the wood should be sealed with a oil base paint or something that prevents moisture from excaping.
- You should have the wood stickered, and it should be waited down.
- You have to keep air, fan 24/7, on it so the wood will dry at an even rate.
- If the moisture is drawn off too quickly, you can “case harden” the wood. You won’t know that until you shove it through a saw. Then it’s too late.
- 45% air moisture will problablely bring the wood down to 8 – 10 %
- Try a small amount first.
Alby
View bill1352's profile
bill1352
130 posts in 2992 days
#11 posted 01-28-2010 01:29 PM
Not sure if Dan with the ebay link is the same guy but there is an ad on ebay for plans to build a home kiln. $25. gives a phone number to talk to the guy if you buy the plans.
-- Keep Your Stick On The Ice
View snowdog's profile
snowdog
1164 posts in 3854 days
#12 posted 01-28-2010 01:59 PM
I have not had a lot of luck drying wood so far but I have not really did a deep dive on the science of drying wood. But what I have seen is that slow is good fast is bad <laugh> not a lot of new news there .
One of my first errors was using a latex paint to seal the ends, yes that did not work. Oil paint keeps the wood sealed so it drys slower (less checking and splits)
View Julian's profile
Julian
880 posts in 3396 days
#13 posted 01-28-2010 01:59 PM
Dan’s link is not to ebay, it’s to another forum that talks about the plans for sale by Daren. They are great plans and Daren is a real stand up guy.
-- Julian, Park Forest, IL
snowdog
#14 posted 01-28-2010 02:00 PM
View Daren Nelson's profile
Daren Nelson
767 posts in 3777 days
#15 posted 01-28-2010 05:04 PM
Zuki your theory is sound and so far the advice you have been given here is good. I will throw this link out to maybe help you, it’s a calculator for EMC (equilibrium moisture content) of wood at a given air temperature and rh (relative humidity) http://www.csgnetwork.com/emctablecalc.html Like you said you will want to go lower than 45% on your unit. Good luck.
