oak top table with pine base?
Forum topic by craftedbyadam posted 01-16-2016 02:29 PM 835 views 0 times favorited 8 replies Add to Favorites Watch
View craftedbyadam's profile
craftedbyadam
17 posts in 805 days
01-16-2016 02:29 PM
Good morning all. I am fairly new to woodworking still but have about 2 dozen projects under my belt now. I have done some hardwood top kitchen islands with a pine base since the base was getting painted.
However, my next project is a toscana dinning table. To try and save on cost I wanted to build the base out of pine and the top using a nice hardwood. Oak, maple, don’t know yet.
My question is would I be able to build the table with oak on top and the base out of pine? My supplier has other hardwoods to pick from if something else would look better with the pine.
Please help
8 replies so far
View dhazelton's profile
dhazelton
2689 posts in 2206 days
#1 posted 01-16-2016 02:52 PM
That’s a picnic table-y sort of support? Why not make it all out of one wood? I think pine and oak together isn’t the prettiest. BUT you could add a third wood into the mix and that might be more interesting.
View Clint Searl's profile
Clint Searl
1533 posts in 2271 days
#2 posted 01-16-2016 03:59 PM
Pine is fine. If you don’t like it, do it over in something else. It’ll be good practice.
View bondogaposis's profile
bondogaposis
4611 posts in 2261 days
#3 posted 01-16-2016 06:25 PM
There is nothing wrong with doing that way. But I doubt you’d save much as most of the wood is in the top any way. Pine is difficult to stain. So if you’re planning on staining it, the extra effort and time needed to make it look good would not be worth it for me.
-- Bondo Gaposis
craftedbyadam
#4 posted 01-16-2016 06:34 PM
I really appreciate the help and tips. You all have been doing this longer than I have!
The problem lies with the 4×4 legs. Where to find 4×4 lumber in oak that won’t cost an arm… i have untreated pine 4×4 on hand and figured I could use those. $6 per piece. It would be a lot more in oak for 4×4 lumber.
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1007 posts in 975 days
#5 posted 01-16-2016 07:00 PM
Use the pine for the base and then use a tinted primer on the pine , like a black or complimenting color of the room and sand thru for a distressed look , then a satin poly. Use the choice wood for the top for the contrast.
-- "Tying shoelaces was way harder than learning to Whistle",,,,,member MWTCA area K. Kentucky
View splatman's profile
splatman
586 posts in 1308 days
#6 posted 01-17-2016 03:26 AM
The problem lies with the 4×4 legs. Where to find 4×4 lumber in oak that won t cost an arm…
- craftedbyadam
Build 4×4s out of 3/4 boards. Miter the edges to fake that solid leg look.
If you start with wide boards, set your TS to 45°, and rip to width and make the 45° bevels in one go.
However you slice it, it may still be cheaper to use solid 4×4s.
Hallow 4×4s give the option to join them together with hidden connectors made of welded steel square tube sized to fit in the void.
View conifur's profile
conifur
955 posts in 1061 days
#7 posted 01-17-2016 03:54 AM
IMHO if this for the house and going to be around for a while and the time and effort, do it right. Let me back up, I dont know what style that is without a pic, I just Googled it, I think I would use Doug Fir for the base, stain and/or dye to your preference, I would then use Birch for the top, or Doug fir all the way, If birch you can dye/stain it to almost anything, I just hate flat sawn oak. I would also distress it if using Doug Fir.
Here are allot of pics
https://www.google.com/search?q=toscana+dining+table&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwi338bK96_KAhWBaT4KHX7nCKsQsAQIaQ&biw=1366&bih=635#imgrc=_
runswithscissors
2658 posts in 1935 days
#8 posted 01-17-2016 08:47 AM
There are router bits available for making lock miter joints. Very strong, and easy to glue up.
