Grain Filler question
Forum topic by shoichi posted 01-16-2016 02:04 PM 1190 views 0 times favorited 13 replies Add to Favorites Watch
View shoichi's profile
shoichi
30 posts in 978 days
01-16-2016 02:04 PM
Hello there,
I decided as my first wood working project to make a wooden chandelier. I had everything planned. My finish schedule was going to be as follows
1- Sand to 220
2- BLO and cured for 7 days
3- Dewaxed Shellac as a sealer
4- Fill the pores with Crystalac.
5- top coat.
So I am in step 2 right now and have hit a road-block. I just found out that the Crystalac grain filler I ordered off of Amazon cannot be shipped to me. I tried to get my hands on Aqua Coat Grain Filler and even that is impossible to get where I live and wont be shipped. I went to Home depot and Lows and neither had any grain fillers. They have the wood fillers that’s good for filling up big holes but not ideal for pores.
So what do I do now that the boiled linseed has already cured. Should I shellac sealer on and then wet sand the surface? Should I wet sand first to fill the pores and then put my sealer on? If I wet sand it now, then do I have to wait for a few days again for the new coat of BLO to cure/dry before I put the shellac sealer on? Can I use Danish Oil over cured BLO to fill the pores? I have heard Watco Danish Oil is water based and I am afraid it may not work well over blo.
Sorry for the newbie question. Thank you very much for advance.
13 replies so far
View Gene Howe's profile
Gene Howe
10822 posts in 3544 days
#1 posted 01-16-2016 03:07 PM
Watco is OIL based. You can wet sand with Watco as a wetting agent. That will create a slurry. Allow it to tack and wipe it off with burlap. The dry sand. It’s a 3-4 day process. Watco dries pretty slow.
View crank49's profile
crank49
4032 posts in 3087 days
#2 posted 01-16-2016 06:50 PM
My Dad made his own filler from fine sanding dust and shellac. Rubbed it on with burlap.
He was a floor finisher for 50 years so I feel sure he knew a thing or two about fillers.
View BurlyBob's profile
BurlyBob
5893 posts in 2381 days
#3 posted 01-16-2016 07:07 PM
I’ve heard of that process Gene mentioned. I’m definitely going to try it on my next red oak project.
View gfadvm's profile
gfadvm
14940 posts in 2806 days
#4 posted 01-17-2016 01:58 AM
Very good advice above. In the future, sand to 180, fill the pores/grain with color matched Timbermate grain filler, sand to 220 (or more if you like), THEN begin finish application.
Gene Howe
#5 posted 01-17-2016 01:27 PM
I use the Watco Method for it’s simplicity and it works really well, Bob. But, Michael’s and Andy’s suggestions are good ones, too.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1292 days
#6 posted 01-17-2016 02:43 PM
If your purpose is simply to fill the pores so you have a flat surface build up a thick surface with shellac and sand down till everything is level. This may take a while.
If your purpose is to change the color of the pores so the piece looks old then you need colored pore filler.
Where are you located that you can’t get finishing products shipped to you?
View Benvolio's profile
Benvolio
148 posts in 2047 days
#7 posted 01-17-2016 09:25 PM
mixing danish oil and pumice powder always works a treat. Rub it in accross the grain, then once it’s cured sand along the grain.
-- Ben, England.
View RogerM's profile
RogerM
798 posts in 2515 days
#8 posted 01-18-2016 01:16 AM
Wunderfil Wood Filler is water based and comes in 8 colors. It can be thinned and used as a grain filler. See
http://www.rockler.com/wunderfil-wood-filler-8-oz-colors
-- Roger M, Aiken, SC
shoichi
#9 posted 01-18-2016 03:16 PM
Thank you everyone for great great advice. my apologies for writing back a few days late.
i live in toronto canada and for some reason, dewaxed shellac and crystalac grain filler is no where to be found here. i’ve checked and visited probbly 30 stores in total. most of the HDs in my area and the rest smaller shops, Lee Valley and woodcraft stores and so on…
i have wet sanded before using Danish oil and it worked great. this time, i wasn’t sure if after having applied BLO and letting it cure for a week, wet sanding wish Danish oil was a good idea because then i’d have to let it dry again for a couple of more days…. this project is due on on Jan 26th so i really can’t afford to sit a few days for the oil to dry since i still have to put 3 top coats on.. but at this point i am gonna try the danish oil and pumice powder and hope for the best..
thanks everyone for your advice… will post a picture once it’s done.
WoodNSawdust
#10 posted 01-18-2016 03:41 PM
I have seen Shellac on LeeValley’s web site. I don’t know if they carry it in their retail stores.
View bondogaposis's profile (online now)
bondogaposis
4925 posts in 2467 days
#11 posted 01-18-2016 04:06 PM
Grain filler should be the first step not the fourth. At this point I would wet sand with Watco as Gene suggests then move on to the other steps, skipping the Crystalac.
-- Bondo Gaposis
shoichi
#12 posted 01-18-2016 04:38 PM
You’re right bondogaposis,
this is my first major project and i messed up…
if i was to use watco danish oil to fill the grain, should i wait a day between each attempt for the oil to cure? This would add two more days to my schedule but i guess it is what it is
Gene Howe
#13 posted 01-20-2016 04:12 PM
I usually give the Danish oil+sanding 72 hours to cure before doing a top coat. Depending on your preferences, another coat of finish may not be necessary after the oil+sanding slurry has been scrubbed off.
