Built-in bookcases and mantel for fireplace surround in a Tudor Revival
Forum topic by Jonathan posted 01-27-2010 07:35 PM 9084 views 0 times favorited 2 replies Add to Favorites Watch
View Jonathan's profile
Jonathan
2608 posts in 3169 days
01-27-2010 07:35 PM
Topic tags/keywords: bookcases built-in mantel mantle fireplace plywood red oak cherry walnut bookcase with doors faceframe chisel pocketholes pocket holes moveable shelves router circular saw clamp saw guide tudor
A year ago Christmas, Santa promised my wife that he’d build built-in bookcases with doors, as well as an adjoining mantel. Well, Santa got busy over the course of that year landscaping most of the yard by laying brick pavers, constructing a couple of raised brick planter boxes, installing a new 8-Zone sprinkler system and sodding after the first snowfall.
Santa promised to do this by Christmas of 2009. Thank goodness my wife knew Santa was a bit occupied over the course of that year and told him she’d rather he took his time and did it up to his standards, rather than trying to rush it before Christmas time.
The challenge here is that Santa has never really done any woodworking before, as the elves have taken care of it in the past. But Santa is ready to tackle this project on his own, as he wants it to be a personal gift.
OK, now that we’ve gotten the backstory out of the way, and everyone is hopefully vaguely up-to-speed, let’s dive into a few more details.
First off, I have very limited experience in woodworking, and am a bit short on tools right now, since I’m just getting started with this hobby, passion, obsession, whatever you want to call the level of involvement you have in woodworking. I am a novice. I don’t have much hands-on experience.
And I suppose I should stop on warn you now that this is going to be a fairly long post/question.
Now, with that being said, I’ve been trying to plan exactly how I want to build all of this, as well, as what materials to use, all to make it look like it fits the character of the house, which is a brick Tudor Revival, or American Tudor… whatever you want to call it.
Here are a couple of pictures to give you an idea of the space I want to use for this project:
Fireplace Surround
Fireplace surround 2
(Sorry for the poor image quality. I had to take this on my phone as all of our photos are on a laptop with issues right now.)
The fireplace actually has a woodburning stove insert, but some or the brick surround is still visible. There is also a little niche right above where the mantle will go. There are two recesses, one on either side of the chimney, with a window in each nook. I will try to attach a picture when I get a chance of the “future construction site”.
The chimney is stuccoed, just like the walls. Level with the bottom of the niche, the chimney begins to taper upward at a noticeable rate. Not so noticeable is the slight taper from the floor up to this level. There is only about 1/2-inch worth of difference in width, but nonetheless, it will have to be accounted for in the design of everything in order to plumb-up the completed project, as I don’t want the wood that’s there to be scribed to match, but rather, I want to eliminate this disparity in width. I am also not sure if I want to remove the two sets of bricks below and to the right and left of the niche, but above all the other brickwork, or incorporate them into the mantel support, either “as-is,” or cover them with wood.
I’m also not crazy about the trim color, but don’t want to change all the baseboard trim, picture rail trim, and window trim just so the bookcases and mantel can be a different color.
Here are a few measurements for the space as it is before I begin the project:
The recesses are not exactly the same widths or depths, but very close. The right recess is 39.5-inches wide at floor level, and 40.0-inches wide where it begins to taper, which is where the mantel will be. Not sure if the top of the bookcases will be level with the mantel, or just below? Seems that it would look more seamless if it flowed as one, but that the mantel would stand out a bit more if it were a step higher? The depth of the right recess is 9-1/8 inches at floor level, and 9-inches at the taper. It is 48-inches from the floor to the bottom of the window trim.
The left recess is 39-5/8-inches wide at floor level, and 40-3/8-inches wide at the taper. The left recess is
8-1/2-inches deep at the floor, and 8-1/4-inches deep at the taper. It is 48-1/4 inches from the floor to the bottom of the window trim.
Some of this disparity might be because of the heavy texture on the walls, but I don’t think the room was originally perfectly proportioned either.
The bottom of the niche is about 45-inches above the floor. The top of the right set of bricks is 44-inches above the floor, while the left set of bricks is 44-3/8-inches above the floor.
The chimney area is 65-inches wide, give or take, depending on where you measure. From the edge of the chimney to where the tile begins below the firebox is 6-3/4-inches on the right recess and 7-inches on the left recess. I figured this measurement would help in possibly designing the mantel stiles/supports as it might look awkward to have to wood overlapping the tile, but maybe not?
The two sets of bricks are 32-1/2-inches apart from inside edge to inside edge. The two sets of bricks protrude about 2-1/4-inches from the chimney. If you run a line across the top of the bricks, the niche opening begins 1-inch above this level.
The floor trim is 40-1/4-inches tall, and will probably be put back in place at the bottom of the bookcases to ensure the continuity of the room.
I suppose that’s enough measurements for now. That at least give you an idea of the space I’m working with.
A few requirements for the bookcases:
-3-shelves inside each bookcase, with the top 2-shelves being moveable.
-2-doors per bookcase, with each door having a hardwood frame, and a glass insert to allow viewing of the bookcases contents.
-inset hinges. I’m currently looking at the Blum 26mm inset hinges.
-doors will sit flush with the faceframe as we want a simple and seamless look.
-no center stile on the bookcases to allow for easy removal of the shelves and also to maximize glass area of the doors.
-the top of the bookcases must sit below the window trim, and either flush with the mantel, or below the mantlel. And the mantel must sit flush with the niche opening, or slightly above if the niche’s floor is also covered in the same wood as the mantlel (like cutting out the mantel top to fit into the niche, if that makes sense).
A few thoughts on the bookcases and mantel:
-We want minimal door frame and faceframe space to allow the maximum amount of space for the glass to show off the contents.
-the internal shelves don’t have to be adjustable, but it was strongly recommended to me to do so by a longtime woodworker/cabinet maker at Rockler.
-the carcasses will be built out of plywood and the back 1/4-inch panel will be rabbeted to square-up and strengthen the case, plus allow a tiny bit more internal room.
-I can’t decide if I want to make the shelves out of hardwood, or plywood with a hardwood edgebanding? The edgebanding would help hide shelf pegs if they are used, but would also limit vertical space between shelves a bit more than a solid piece of hardwood.
-I’m not sure exactly how deep I want to make the bookcases? They will definitely be deeper than the recesses they’ll be in, but by how much, I’m not sure. And when they protrude past the chimney, it seems to me that I will need to compensate for this by building out the stiles for the mantel, as it seems that the mantel/mantelsurround should protrude into the room farther than the bookcases to keep everything looking right.
-I want to keep both the bookcases and mantel looking as “Tudoresque” as I can. So, I don’t know if I should use rougher wood for the mantel Like a timber) and almost just have a big heavy beam, or what I should do? I don’t want to go all-out Craftsman style, but it seems to me that what I’m describing is a bit more Craftsman in style. I guess I’m wondering how I can sort of do a hybrid design between the two, melding both styles together, if that’s possible.
-It also seems to me that the design of the mantel is what will ultimately dertermine the character of the overall project, in how “big” I make it, what sort of design elements I use for the trim, how I support the mantel, and what the surround looks like. The bookcases just need to mimic the mantel, but since most of their surface area is going to be glass, I’d think the mantel will make the main statement.
-The trim around the room is red oak. I’m not sure if I want to continue this trend, or change woods for this project. I’m certainly not opposed to using a different wood. I’d really rather only use oak for this if I could find quartersawn, as I like the look. Any suggestions on this would greatly be appreciated.
-I’m thinking a good depth for the mantel is about 7-inches.
Sorry for the unorganized posting here. I’m mainly trying to get thoughts down on all this. I know there is a lot to respond to here, but if you even have one bit of advice on one little part of this project, please chime in!
Thank you in advance for your input,
Jonathan
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
2 replies so far
View Icemizer's profile
Icemizer
88 posts in 3658 days
#1 posted 01-28-2010 08:51 PM
Here is what I came up with for this.
http://farm3.static.flickr.com/2694/4311407531_bb0c1ebd97_o.jpg
I would get rid of the one set of bricks currently on the mantle. Keep the level of the bookcases so they start where the bottom of the mantle stops. Where the bookcases meet the exisiting chimney I would put a larger face frame to cover the slope. Make that casing the same size as the depth of the mantle.(thought of that after the picture was done.) Definitely put in moveable shelving. You can route slots in the bottom of the shelves that the pins fit in to hide them if you need to.
-- Say what you mean and mean what you say.
Jonathan
#2 posted 01-28-2010 11:02 PM
Icemizer,
I added a link back to this page on the blog I started on this topic. The blog on this topic can be found here, including some more information added to my original posting on this page: http://lumberjocks.com/JonathanG/blog/13322
You gave some excellent information, including the sketch… thank you! I will have to show the sketch to my wife, as I’m not sure she’s totally visualizing the space yet, and with that layover on a picture of the actual room, that should help.
I don’t think I want just the mantel running the width of the chimney, as it seems a bit disjointed/out-of proportion. If I can put a bit of wood underneath the mantel (a friese?), I’m thinking that’ll look more complete and really make it appear as one unit that runs the entire width of the room. That was why I was thinking about setting the mantel on top of the bricks, but covering the bricks with a shell of wood so that they look like the ends of exposed beams. I would also add a third exposed beam to match in the center of the mantel, following the rule of 3s, and had even toyed with putting a box beam at each end of the mantel to even out the look, although then the boxes won’t be spaced evenly. Maybe I should just yank the bricks out and build the box beams anyway?
Your sketch helps clarify the sloping chimney issue. It would be sort of a pillar effect. Now if I did that, I could have a large beam stretch across, and nothing more for the mantel. That would require removing the bricks, or notching out to accomodate them in the bottom, or just build right over them with a box going across that looks just like a beam. Something like this, maybe:
http://lumberjocks.com/projects/27124
That would be substantial enough, something that is maybe 7”x7” or so, sitting on the pillars that stick out as far, or almost as far. Not sure if a sort of rustic looking beam would like right though?
And then the doors on either side of the mantel would basically be flush with these pillars when they were opened, basically eliminating the right side of the faceframe on the lefthand bookcase and eliminating the left side of the faceframe on the righthand bookcase.
