looking for a raised panel style name
Forum topic by depictureboy posted 01-27-2010 04:29 PM 2044 views 0 times favorited 9 replies Add to Favorites Watch
View depictureboy's profile
depictureboy
420 posts in 3550 days
01-27-2010 04:29 PM
Topic tags/keywords: question
I saw a really neat design I want to use for my bedroom remodel that I am working on now. Simply put its a panel that sits flush with the front of the rails and stiles and has a groove about 1/8 thick all the way around it.
I saw it while I was doing some research on MLCS router bits, but now i cant for the life of me remember the search terms that got me to the pictures…I think it is a form of shaker panel maybe like the 15 degree…but I havent been able to find any really good pictures of it.
The picture I saw was of a dark interior panel with light rails and stiles..it was really really elegant looking…
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
9 replies so far
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 3498 days
#1 posted 01-27-2010 05:35 PM
Here is a mitered door and a cope and stick door similar to what you are saying.
Every company will name the door different. You don’t need any specialty bits for these. Simply make the door frame like the one I blogged (shaker door becomes….) and then rabbet the panel all the way around using the dado set on the table saw. You could also bevel the panel edges on the table saw as well. HTH
depictureboy
#2 posted 01-27-2010 05:37 PM
yep the bottom is very close to what I was looking for…Is that hickory?
kolwdwrkr
#3 posted 01-27-2010 05:47 PM
The supplier called it pecan, so we’ll say hickory. LOL. If you want a bevel on the frame and you are doing the cope and stick style you will most likely need to find a cope and stick bit for that profile. You don’t need a bit if you miter the corners.
kolwdwrkr
#4 posted 01-27-2010 05:51 PM
depictureboy
#5 posted 01-27-2010 06:08 PM
actually I was going to have them flat faced…ill post my sketchup idea when I get it worked out…
View rhett's profile
rhett
742 posts in 3575 days
#6 posted 01-27-2010 09:51 PM
You can make the panel with a dado cutter. Simply take the groove depth, minus spaceball diameter, of your rail and stile add on the width of the groove you want and just make a cut front and back all the way around. If your tongue is centered as well as the grooves in your rail and stile, you will have a flush front door with an equal groove all the way around. Hope that is helpful.
-- Doubt kills more dreams than failure.
depictureboy
#7 posted 01-27-2010 11:13 PM
hmm I thought I posted this…guess not…
I am actully going to make the center panel a little proud of the rails and stiles…I think (at least from my sketchup) that looks better than flush…put a minor roundover on the edge of the panel and I think it will look pretty cool
one thing I was wondering though in my lost post…would 1/16 be too narrow with wood movement? I have 1/8 now…what do you think?
rhett
#8 posted 01-28-2010 04:01 AM
I think you can still use the dado and just grind the top bearing off a 1/8” router bit, offset the fence on your router table and you will get that nice roundover you want on the upper face. For peace of mind I would go with 1/8 space.
depictureboy
#9 posted 01-28-2010 07:47 PM
yep…thanks rhett…I was planning on using my dado blade or straight router bit…I cant wait to get started…
