Which Wixey angle gauge?
Forum topic by Rick_M posted 01-15-2016 04:36 AM 1354 views 0 times favorited 36 replies Add to Favorites Watch
View Rick_M's profile (online now)
Rick_M
11099 posts in 2284 days
01-15-2016 04:36 AM
  • Wixey with backlight $29 (original version but with light)
  • Wixey with “Dead Level” technology $39
Back light sounds great but “Dead Level” sounds like a good feature too although I’m not sure what it does, something about permanently calibrated to the earth or something.
-- http://thewoodknack.blogspot.com/
36 replies so far
MrUnix
6336 posts in 2103 days
#1 posted 01-15-2016 05:18 AM
From a cursory look, the $40 one just has a built in level. Not sure how often you use a level, but I’m sure it would be more accurate than those bubble in a vial things :) The cheaper one (type 2) is a bit less accurate (+/- 0.2 degrees) and uses 1 AAA battery but has a backlight, and the $37 (type I) is a bit more accurate (+/- 0.1 degrees) and uses a 3v button battery – no backlight. Same specs as the one with a level.
Choices, choices, choices….
View bearkatwood's profile
bearkatwood
1477 posts in 915 days
#2 posted 01-15-2016 12:43 PM
My vote is for the back light one. That’s the one I have and I use it constantly with very good results. I don’t ever use a level in my shop as everything in my shop is out of level so I just zero out to each tool I am setting up. I don’t often endorse a tool unless I think it rocks and wixey has an amazing product. I skimped before and bought the harbor freight version which now lives in the landfill.
-- Brian Noel
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2273 days
#3 posted 01-15-2016 01:47 PM
I’d vote for the cheaper one. I have that one as well. The only reason I suggest it is because it’s cheaper. Like Brian said, it’s more useful to have things calibrated to the tool than to earth. I don’t know what situation a woodworker would run into where they needed something referenced to the earth, or whatever it does. Even if you’re building a table or something, its best to have a dead flat reference surface to go off of. Now, if you were building a deck or something, maybe it’d be useful?
View jeffswildwood's profile
jeffswildwood
2822 posts in 1881 days
#4 posted 01-15-2016 01:51 PM
I have the wixey with the button battery. A gift from my Son two years ago. I absolutely love it. I can finally get accurate 45’s from my cheap skil table saw. The battery lasted about a year before I needed a replacement. Setting it back to 90 degrees is a snap also. I tried using squares, even the drafting version, and would always still be a little off. I also used it to check which of my squares are actually square. Great product!
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View doubleDD's profile
doubleDD
7104 posts in 1947 days
#5 posted 01-15-2016 03:09 PM
I have the $30.00 one and had it about 5 years now. I believe it to be very accurate with the results I get. For me no need to look at something new when everything works fine.
View waho6o9's profile
waho6o9
8099 posts in 2481 days
#6 posted 01-15-2016 03:48 PM
Great responses above and my 30.00 version has earned it’s keep.
It’s kinda neat to put the angle gauge on a miter blade and check to see if the
blade’s warped. I put the AG (angle gauge) on different locations and got different
readings on the miter blade.
Then I replaced the blade and the AG read zero at every location and my cuts were
90 degrees again.
Major relief. :)
Rick_M
#7 posted 01-15-2016 03:55 PM
I can see the Dead Level version being handy for building or calibrating levels but not sure there is much use for a woodworker otherwise.
View Jim Finn's profile
Jim Finn
2614 posts in 2826 days
#8 posted 01-15-2016 04:36 PM
I have the one with the button battery. IT works well but I have to remove the battery after using the tool because otherwise it will discharge before I need it again. I replaced many batteries before doing that. I understand there are some that use different batteries AAA or 9Volt. I would opt for one of those.
Rick_M
#9 posted 01-15-2016 06:36 PM
Must have been the original that used a button battery, both of these use AAA.
I think I will go with the $40 version because it is rated more accurate, after all, accuracy is the reason I want one; and it has a longer battery life.
View rubber_ducky's profile
rubber_ducky
36 posts in 782 days
#10 posted 01-15-2016 07:40 PM
The backlight seems a bit gimmicky IMO. Who sets up their TS in the dark?
Rick_M
#11 posted 01-15-2016 07:44 PM
Once you hit about 45, it’ll start to make sense ;)
MrUnix
#12 posted 01-15-2016 07:49 PM
Backlight is nice, but that model is less accurate than the other two if that makes any difference to you. The other two have the same accuracy, but one has a built in level and uses AAA batteries, the other one is $3 cheaper and uses button type batteries. I’d probably spend the extra $3 and get the one with a level as well… don’t use them often, but it would be nice to have a precise one when I did. All three function the same for finding angles (put on reference surface, push reference button and start measuring angles from that reference). YMMV.
View Richard's profile
Richard
1916 posts in 2594 days
#13 posted 01-15-2016 07:58 PM
Once you hit about 45, it ll start to make sense ;)
- Rick M.
I Hit 45 a long time ago and I still don’t setup my TS in the dark and some of the backlights actually seem to make the gauge harder to read. Maybe that’s just an Over 45 thing . :)
My Wixey uses the 3v button battery and doesn’t have the level , and it will discharge quickly if I leave the battery in when not using it even for a couple of days. I also have the HF one and it uses 3 of the button batteries and also goes dead quick if I leave them in.
View 716's profile
716
502 posts in 820 days
#14 posted 01-15-2016 10:28 PM
This will always be more accurate and easier to use. And cheaper too.
-- It's nice!
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2213 days
#15 posted 01-15-2016 10:36 PM
- 716
How to those work to set you table saw blade at 36.8 degrees?
I like my Beall Tilt Box Angle Gauge. Seem to be pretty accurate.
showing 1 through 15 of 36 replies
