Ridgid bs14000 band saw - would you?
Forum topic by haeffnkr posted 01-27-2010 06:50 AM 16323 views 2 times favorited 21 replies Add to Favorites Watch
View haeffnkr's profile
haeffnkr
6 posts in 3035 days
01-27-2010 06:50 AM
Hello,
If you had a chance to buy a refurbed one for 250 and needed a decent saw, to be used by an occasional woodworker on a budget, would you buy it?
Thanks Kevin
21 replies so far
View Gary's profile
Gary
9330 posts in 3426 days
#1 posted 01-27-2010 07:32 AM
Yep
View Jeison's profile
Jeison
968 posts in 3101 days
#2 posted 01-27-2010 12:42 PM
i second that Yep and raise you a sure
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
View bsherman's profile
bsherman
76 posts in 3521 days
#3 posted 01-28-2010 01:22 AM
Be careful. Search the Ridgid woodworking forum about this tool. The other Ridgid stuff is great, but this is the worst tool that they have. I know a lot of people end up with good ones, but it’s a gamble. The bad ones have serious vibration problems.
They told me the same thing on the Ridgid site, and I bought one anyway. Paid about the same thing too. Being new to woodworking the vibration didn’t seem too bad when I checked it out. But it took time, effort and money to get the vibration sorted. Mine is fine now but I would never do it again. (Sorry)
-- Brian
View Rasta's profile
Rasta
120 posts in 3435 days
#4 posted 01-28-2010 01:38 AM
I have a Ridgid bandsaw that I am happy with, I have made many upgrades including 6 inch riser block and balancing the wheels, I have put work into but it works fine for me. This is also the only bandsaw I have ever had or even used for that matter so my opinion is might not mean that much.
-- Roscoe in Iowa
View syenefarmer's profile
syenefarmer
488 posts in 3074 days
#5 posted 01-28-2010 03:19 AM
I agree with bsherman, this BS is not a very good one. It’s not only the Ridgid Forum that has bad things to say about this BS either. Search a few of the other forums and you’ll find as many or more negatives than positives.
View Bobby's profile
Bobby
108 posts in 3046 days
#6 posted 01-28-2010 04:08 AM
Sigh… I was looking at the Ridgid 14” today… and came this close to buying it at HD for $469. Right now I’m TRYING to use a Delta 10” that I bought about 6 or 7 years ago. That was back in the day when I would buy something without checking with someone who knew something about tools. I was pretty new to woodworking power tools back then and really didn’t know anything about brand names. I’ve learned a lot since then.
And so… the Ridgid just managed to be in my budget range… but JUST. Any suggestions??? Do keep in mind that I won’t be doing any serious 6” resawing with it… in fact, it will be used very easily. I don’t think I’d have to worry about burning it out.
—Bobby
haeffnkr
#7 posted 01-28-2010 04:37 AM
Hello,
Thanks for the replies so far.
I have read the 2 or 3 reviews on this site regarding this band saw.
I understand you have to replace the blade and add cool blocks, maybe balance a wheel and add some mdf to the stand. Are the folks who dislike them have more problems than that?
If so what?
What saw would you buy for 250 that is better than this one?
View PurpLev's profile
PurpLev
8535 posts in 3642 days
#8 posted 01-28-2010 04:44 AM
It may not be 250, but if you can raise the budget to ~400 you can get an enclosed base Jet or similar on craigslist which would be a much more solid BS in the long run.
I was in the same boat you are now, and was even trying to settle for a 12” bandsaw in order to stay ‘within budget’... but the more I researched, the more I understood that in the long run I’d be kicking myself for that purchase. I saved up some more and waited a little longer, and got the Rikon 14” deluxe… definitely above and beyond the 250 budget. but it’s also above and beyond anything that I ever need to do with a Bandsaw – and then some.
my point is – don’t be in a rush to buy something on the cheaper side of things. find out what it is that you plan to do with it- save up some more, and buy something that will do what you need to do + a little more so even if you outgrow some , and find new ideas that you’d like to use it for – you’ll have a machine that is capable to grow with you.
my $0.02
bsherman
#9 posted 01-28-2010 04:49 AM
I had to do quite a few things to get mine where I was happy. Check under my projects. http://lumberjocks.com/projects/26096
Here is a list of the problems with mine. In fairness some of them could have been caused by the previous owner, but I doubt it since it had little indication of use. Wheels out of balance and out of round, lower bearing failed (and I think its bad again), pulleys out of round, tension rod broke.
In addition to those, I replaced the base with a plywood stand and moved the motor under the saw. The problem with the motor being behind the saw, is that unless everything is perfect, it pulls the saw back and forth causing more vibration. Moving the motor under causes any pulling to be up and down against the weight of the saw.
I tried all combination of stuff with the metal base like, with/without the rubber gromets, new gromets, plywood under the metal base, plywood middle shelf, link belts, etc.
-- Brian
View drfixit's profile
drfixit
318 posts in 3137 days
#10 posted 01-28-2010 05:25 AM
I lucked up with the one i bought used I guess. Other than cool blocks, new tires and timber wolf blade mine seems perfect. I like the idea of moving the motor under it like Brian did. Mine is mounted to a night stand made of solid pine (I lost the metal stand somewhere off the back of the truck on the way home) and I did paint it grey because I didnt like all that orange
-- I GIVE UP!!!! I've cut this @!&*!% board 3 times.... its still too short!
bsherman
#11 posted 01-28-2010 05:49 AM
Dang drfixit, I just put my metal stand on the curb last week. :-)
I like the grey paint job.
-- Brian
View papadan's profile
papadan
3584 posts in 3362 days
#12 posted 01-28-2010 05:54 AM
He’s looking at a refurb, may be fixed already. I do have a BS1400 that I bought new in 2001. Yep, original gray, and still using the original tires, never balanced the wheels, have not had any vibration worth noticing.
Beginningwoodworker
13345 posts in 3666 days
#13 posted 01-28-2010 05:56 AM
This saw gets bad reviews, but for what you wont it may be ok.
haeffnkr
#14 posted 01-28-2010 06:05 AM
Thanks for the comments –
So there are 2 of these saws in the area.
One used and one refurbed.
One I spun the refurbed one of them around by hand, seemed to track fine on the wheel and the top of the wheel appeared to be true.
I did not see it run.
What can I check to be sure I get a good one?
What kind of vibration are you all talking about?
I am novice to Band Saws, sorry for the questions.
thanks Kevin
bsherman
#15 posted 01-28-2010 06:14 AM
I wouldn’t buy one unless you can see it run. You can try to balance a nickel on edge on the table while it is running. I can do this on mine but it’s a pretty high standard for a bandsaw. At it’s worst point, I couldn’t set a tape measure on top without it eventually sliding off.
Another thing to watch/feel is how much the tension knob on top is moving.
Sometimes they get a strange pulse too if the wheels are out of round. It would run OK for 30 seconds, then the high spots would align, and it would start shaking for 30 seconds, then get better, etc.
-- Brian
