Glue recommendations
« back to Coffee Lounge forum
Forum topic by Steve Friedman posted 01-27-2010 02:37 AM 953 views 0 times favorited 6 replies Add to Favorites Watch
View Steve Friedman's profile
Steve Friedman
19 posts in 3143 days
01-27-2010 02:37 AM
I’m about to start a cold moulding project and I’m interested in recommendations for adhesives. A friend told me that the standard glues (Titebond and yellow glue) are not used for this technique.
Does anyone have any experience – recommendations?
I’d like to hear from you.
Steve
-- Steve
117063 posts in 3543 days
#1 posted 01-27-2010 02:40 AM
Cold moulding is a new term to me.
View Jeison's profile
Jeison
968 posts in 3073 days
#2 posted 01-27-2010 02:52 AM
http://en.wikipedia.org/wiki/Boat_building
“Cold-Molding is a composite method of wooden boat building that uses many different layers of thin wood, called veneers, oriented in all different directions, resulting in a strong monoque structure, similar to a fibreglass hull. Usually composed of a base layer of strip planking followed then by multiple veneers, cold-molding is becoming popular in very large, wooden superyachts. “
mmm…..superyachts…
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
Steve Friedman
#3 posted 01-27-2010 02:53 AM
Hi Jim,
I’m beginning to understand that you live on this site. Cold molding is what my friend describes it I don’t know if it is the correct term or not. Anyway, it involves resawing stock material into thin strips ( 1/8 inch or thinner) and then pressing them into a form to create curved pieces. I guess it only differs from other bend wood techniques because it doesn’t use heat to change the fibers.
Hope that helps.
Steve
-- Steve
View Gene Howe's profile
Gene Howe
10355 posts in 3394 days
#4 posted 01-27-2010 04:02 PM
David Marks has done a few projects like this for large ovals and other curved work. He uses a plastic resin glue. Aliphatic (he says) will allow creep after cured.
IIRC, he clamps every 4-6 inches!
View John Ormsby's profile
John Ormsby
1283 posts in 3703 days
#5 posted 01-27-2010 05:51 PM
West System type Epoxy or Urea glues are commonly used for cold molding. You are basically laminating pieces to make a structurally sound project. These types of glues, when set, will help retain the shape curved surfaces with little or no deflection. Epoxies can be used in colder temps. In cold climates, wrapping the glue-up with blankets and using a safe heater will help in the curing process.
-- Oldworld, Fair Oaks, Ca
View Jim Jakosh's profile
Jim Jakosh
20289 posts in 3071 days
#6 posted 01-28-2010 04:09 AM
For any boat project, I would use West System Epoxy. It penetrates the wood about 1/32” and is very strong and waterproof. It also works well with fiberglass or kevlar cloth. We used it on hovercrafts that ran in the winter as well as summer.
