Question about lever caps
Forum topic by Jimi_C posted 01-26-2010 11:20 PM 1082 views 0 times favorited 7 replies Add to Favorites Watch
View Jimi_C's profile
Jimi_C
507 posts in 3262 days
01-26-2010 11:20 PM
Topic tags/keywords: plane
I recently won a Stanley #8 on ebay that is in pretty beat-up shape, including a broken lever cap (which partially explains why I got it for < $10…). Seeing as the #8 lever caps are pretty rare and #7’s aren’t, would it be possible to use a #7’s as a temporary substitute? The #8 is 2 5/8” whereas the #6/#7 is 2 3/8”... does that 1/4” really matter that much as far as blade chatter is concerned?
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
7 replies so far
View PurpLev's profile
PurpLev
8536 posts in 3675 days
#1 posted 01-26-2010 11:32 PM
you really do want that extra 1/4” of support especially since the #8 takes wider bites from the lumber – it all adds up. you could give the #7 lever cap a try if it’s reasonably priced. although for the long run a proper lever cap would be recommended.
View SST's profile
SST
790 posts in 4222 days
#2 posted 01-27-2010 12:04 AM
From my experience, the extra 1/8” per side should not really be an issue if you’re not hogging off really thick cuts. You can also get an aftermarket thicker blade to minimize the chatter or flex (if any). That said, I would keep looking for the correct one anyway. -SST
-- Accuracy is not in your power tool, it's in you
View bigike's profile
bigike
4052 posts in 3315 days
#3 posted 01-27-2010 12:22 AM
yea u should be able to get one on ebay keep tring.
View WayneC's profile
WayneC
13754 posts in 4124 days
#4 posted 01-27-2010 12:25 AM
Also look at junker #8s you might find one with cracks or such with a good lever cap that would go cheap.
View blackcherry's profile
blackcherry
3338 posts in 3850 days
#5 posted 01-27-2010 12:38 AM
Some of the big dealer on e bay have plenty of extra parts. Send out some inquiries in the “ask the dealer a question” box. You’ll get a response fast and might get it free if you win one of there auctions…Blkcherry
Jimi_C
#6 posted 01-27-2010 02:02 AM
Thanks for the feedback. On all of ebay, there was a single #8 lever cap up for grabs, and I didn’t win it :( Some of the antique plane sites I’ve looked at all list the part as rare, especially if I want to stay period-correct (I’ve dated my plane to 1910-18), so it’s quite expensive if I were to buy one.
So, I plan to keep looking (I’ve got a saved search that emails me daily with possible matches), I was just curious if I could get away with using the #7 instead since they are fairly common and much cheaper. @blkcherry, I’ll look into your suggestion as well.
View ajosephg's profile
ajosephg
1880 posts in 3588 days
#7 posted 01-27-2010 02:48 AM
Check Rose Tools. I’ve visited their place and they have more antique tools and parts in one place than I have ever seen. You’ll need to call them because their websiite only shows a small fraction of what’s available. Also, there is no hard sell, and they won’t rip you off.
-- Joe
