Measuring Dovetail Angles
« back to Joinery forum
Forum topic by tburkhart posted 01-13-2016 06:18 PM 1444 views 0 times favorited 18 replies Add to Favorites Watch
View tburkhart's profile
tburkhart
8 posts in 1122 days
01-13-2016 06:18 PM
Hi, I am wanting to jump in and make my first attempt at hand cutting dovetails. However, I do not have any specialized equipment for marking the angles. I have some rulers, combo square, but nothing to set angles… not even a protractor… any ideas? Ive heard there are measurements to draw out a paper (or wood if you make it) template. Im not really sure what angle my dovetails even need to be at honestly.
18 replies so far
View Paul's profile
Paul
721 posts in 1801 days
#1 posted 01-13-2016 06:36 PM
Here is a very detailed article to get you started.
https://www.canadianwoodworking.com/tipstechniques/hand-cut-dovetails
Paul
View GregTP's profile
GregTP
63 posts in 1179 days
#2 posted 01-13-2016 06:42 PM
Thats the beauty of dovetails, there really aren’t many tools needed. You can pick up small dovetail markers for $10 on amazon. Or, for only a few dollars you can find a bevel gauge at any hardware store.
Typically your angles are 1:5 for soft woods and 1:8 for hardwoods, or something close to that. You can use the stamped measurements on a typical framing square to set the angle on a bevel gauge and lock it down.
-- From exercise machine warning label: "Step ladders can cause injury and even death; the ROM machine is more dangerous than a stepladder"
Smitty_Cabinetshop
15800 posts in 2854 days
#3 posted 01-13-2016 06:50 PM
You could just eyeball them. I’ve never marked the angle before cutting. Just cut all the right sides, then all the left sides holding the saw consistenly each time. It’s not hard, and you can jump right in.
View bandit571's profile
bandit571
21983 posts in 2919 days
#4 posted 01-13-2016 07:00 PM
I tend to “cheat” a bit. I have an old 1/2” router bit. I trace along the edges to mark out the angles
There is a bevel gauge to help carry the angles to the otherside of the board. A small square for the straight lines needed. Yes, I do use a sharp pencil
Then saw a bit, no need for a fancy saw..
Then some chisel work. Pins can be simple to do..
Then use these to mark out the other half of the joint, saw while leaving the lines in place. Then the chisel thing, again..
Chop in from each side. Pare to fit.
Just practice on scrap until it seems to go like clockwork.
tburkhart
#5 posted 01-13-2016 09:22 PM
Thanks for the advise! great pics btw!
117417 posts in 3813 days
#6 posted 01-13-2016 11:00 PM
View rwe2156's profile
rwe2156
3230 posts in 1716 days
#7 posted 01-14-2016 01:22 PM
I agree with Smitty.
My advice is starting out I wouldn’t worry about marking out the angles but if you want to, you need either a bevel gauge, DT angle gauge or a homemade DT marking gauge. A protractor is not needed. For a 1 in 8 DT you simply draw an “L” with the vertical 8” and horiz 1” the hypotenuse is the angle set your bevel gauge accordingly.
Watch a couple videos, see the different approaches, see what works for you.
Learn how to fix mistakes (the parts edited out of the videos ha ha) because they WILL happen .
Learn what good chisels and saws are all about compare to what you’re using.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1412 days
#8 posted 01-14-2016 01:31 PM
+1 for what Smitty said.
I have a couple of Frank Klaus DVDs and he just eyeballs the angles. He cuts the tails first and then uses the cut tails as a template to draw the pins.
View bearkatwood's profile
bearkatwood
1674 posts in 1247 days
#9 posted 01-14-2016 05:49 PM
I like to use 1:6 for soft woods and 1:8 for hardwoods.
Smitty has a good point, as long as your pins and tails match up well, the 1:6 or 1:8 angle is not super critical, but watch out for the short grain issues like what is shown in bandit571s’ second picture. Excellent dovetails, just watch your angles go with the grain bandit.
Practice will be a great teacher, just remember the saying. “How do you get to Carnegie Hall?”
Two things to start with in woodworking are learning how to sharpen yous saws and chisels and keep them sharp and then learning how to chisel and saw in a straight line repeatably. Once you have those two things down the rest is just adding to it, but build on those first and good luck.
Best to all
-- Brian Noel
bandit571
#10 posted 01-14-2016 06:10 PM
Smitty has a good point, as long as your pins and tails match up well, the 1:6 or 1:8 angle is not super critical, but watch out for the short grain issues like what is shown in bandit571s second picture. Excellent dovetails, just watch your angles go with the grain bandit.
Best to all
- bearkatwood
Note where the waste is marked out in the above photo. This board is the “Pin” board, as I do pins first on the dovetails I do. Even on these..
Going from this, to this..
A hardwood works better…
bearkatwood
#11 posted 01-14-2016 10:32 PM
Going from pins or tails doesn’t matter when you are making dovetails on an angle or straight. I was trying to show you that the pins and tails don’t run perpendicular to the angled cut like a squared cut. They will be at two different angles to best run with the grain of the wood. This is done to keep them stronger and eliminate the short grain problem. If they work well for you the way you make them, fine. I was showing the way of constructing angled dovetails that doesn’t have the short grain issues.
In woodworking there are more than one way to get there. Just like golf, if you get the ball in the hole, you did it right.
-- Brian Noel
View paratrooper34's profile
paratrooper34
915 posts in 3188 days
#12 posted 01-14-2016 11:00 PM
Going from pins or tails doesn t matter when you are making dovetails on an angle or straight. I was trying to show you that the pins and tails don t run perpendicular to the angled cut like a squared cut. They will be at two different angles to best run with the grain of the wood. This is done to keep them stronger and eliminate the short grain problem. If they work well for you the way you make them, fine. I was showing the way of constructing angled dovetails that doesn t have the short grain issues.
- bearkatwood
Unfortunately there are some who have the “My way or the highway” mentality. Makes for some interesting posts though.
-- Mike
View TheFridge's profile
TheFridge
10815 posts in 1722 days
#13 posted 01-14-2016 11:05 PM
Get yourself a bevel gauge. You can use it for a lot more than dovetails. Just my recommendation.
bearkatwood
#14 posted 01-15-2016 12:39 AM
I am not the my way or highway kind, just showing something maybe you hadn’t seen. You can choose to learn something new or do it the way you have always done it. It makes no difference to me, I am just trying to help.
https://www.youtube.com/watch?v=Pv9fSuVqjKo
-- Brian Noel
paratrooper34
#15 posted 01-15-2016 12:52 AM
I am not the my way or highway kind, just showing something maybe you hadn t seen. You can choose to learn something new or do it the way you have always done it. It makes no difference to me, I am just trying to help.
- bearkatwood
I agree with you, didn’t mean it to seem like you were that way. Sorry.
-- Mike
