Screw Tapping a Green Bench Leg
Forum topic by revF posted 01-13-2016 05:28 PM 550 views 0 times favorited 1 reply Add to Favorites Watch
View revF's profile
revF
2 posts in 1065 days
01-13-2016 05:28 PM
Topic tags/keywords: workbenches leg vises wooden screws screw tapping shrinkage green wood
Hi there. I am about to have a bench leg tapped for a 2.5 inch maple screw for a leg vise. The leg I want to use is green ash (both the species and the moisture content are “green”). The leg is from a tree I milled myself about six weeks ago and the leg is quarter sawn (as much as any timber is truly quarter sawn – the grain is vertically perpendicular to the face side of the timber). Its dimensions are 3.75×6. My question is how might the screw function be affected over time as the timber continues to season?
Initially I worried that the shrinking leg might actually pinch the (already dry) screw and bind it. However, I think that holes generally become elliptical as wood seasons which may have the same or opposite effect. I know it’s a bit of a gamble either way. As long as it doesn’t render the vise ineffective or unusable I can live with it.
I have some more seasoned timber I can use if necessary so it’s cool either way. Share any thoughts and thanks.
1 reply so far
View HokieKen's profile
HokieKen
7110 posts in 1339 days
#1 posted 01-13-2016 08:15 PM
Green wood only milled six weeks ago that is that thick is not a safe bet IMHO. I wouldn’t count on it working in the long run. If you really want to use that wood, I’d cut a 3” square mortise through and get a 3” block of stable wood tapped and glue it into the mortise. Given a choice my preference would be to use a stable wood for the whole leg.
-- Kenny, SW VA, Go Hokies!!!
