Opinions on Delta 14" band saw c55kxdae1922a
Forum topic by namrufmot posted 01-13-2016 01:19 AM 1105 views 0 times favorited 8 replies Add to Favorites Watch
View namrufmot's profile
namrufmot
54 posts in 769 days
01-13-2016 01:19 AM
Found someone selling this IMMACULATE band saw for under $100…it runs perfectly. I’ve been in the market for a band saw, so it is either something like this or a Harbor Freight (UGH).
Anything I should know about this specific model?
8 replies so far
MrUnix
6327 posts in 2101 days
#1 posted 01-13-2016 01:34 AM
I have no idea what a c55kxdae1922a is, since that isn’t a Delta model number that I’ve ever seen. Delta model numbers start with a 2 digit prefix followed by a three digit number depending on configuration (stand type, motor, etc..). The cast iron 14” models should use a 28 prefix (ie: 28-xxx). But for $100, I don’t see how you could go wrong… the 14” Delta remained basically unchanged since they were introduced up until they were discontinued a few years back.
namrufmot
#2 posted 01-13-2016 02:03 AM
I have no idea what a c55kxdae1922a is, since that isn t a Delta model number that I ve ever seen. Delta model numbers start with a 2 digit prefix followed by a three digit number depending on configuration (stand type, motor, etc..). The cast iron 14” models should use a 28 prefix (ie: 28-xxx). But for $100, I don t see how you could go wrong… the 14” Delta remained basically unchanged since they were introduced up until they were discontinued a few years back.
- MrUnix
Thanks…some googling told me it is model 28243X
View conifur's profile
conifur
955 posts in 1054 days
#3 posted 01-13-2016 02:05 AM
I just Googled it, nothing there!!!!!!!!!!! Except your post, and the sellers, it is not a model #, maybe a catalog # from some place that sells it.
MrUnix
#4 posted 01-13-2016 02:05 AM
Yup – your basic cast iron Delta 14” band saw… for less than $100 I’d be all over it.
View Sprung's profile
Sprung
93 posts in 1618 days
#5 posted 01-13-2016 02:09 AM
$100 on that saw is a you need to be on your way to buy it as soon as you see the listing price. Very good price on a Delta 14” bandsaw. And a riser block is available if you ever need more resaw capacity.
-- Matt, SW MN, https://www.facebook.com/anewcreationwoodworks
conifur
#6 posted 01-13-2016 02:10 AM
I just Googled what you posted with the pi and nothing. looks like mine but that is not the Delta #
View TheFridge's profile
TheFridge
8841 posts in 1388 days
#7 posted 01-13-2016 02:13 AM
28-243
Have one. Good saw. I’d buy everyone I saw for 100$.
conifur
#8 posted 01-13-2016 02:19 AM
The # is 28-243!!!!!!!!!!!!!!!!!!
http://vintagemachinery.org/photoindex/detail.aspx?id=7076
On it like stink on a bad smell!!!!
I paid 500$ for mine used with the riser block and optional 3/4 hp motor like new.
