| Forum topic by remsen | posted 1213 days ago | 3296 views | 0 times favorited | 17 replies | ![]() |
17 replies so far
#1 posted 1213 days ago |
I would just fill it in with tinted epoxy then re-surface it. That would leave it as a character mark but make it so bacteria etc don’t pool in the crack. If it was in the dump, I might let it sit in the shop or house for a good long while to get out any moisture it aquired when outdoors. May have been what caused the crack. -- Jimmy, Oklahoma "It's a dog-eat-dog world, and I'm wearing milkbone underwear!" |
#2 posted 1213 days ago |
I’ve never tired to fix somethnig that large. Some off the wall ideas are to rig up a jig using a large jack ( several tons) and use the jack to sqeeze the crack shut. Or maybe something with hand winch so you have more leverage that the handles on the pipe clamps. Another would be to cut the block on both sides of the at the crack and then glue the rest back together. How many people does it take to pick the thing up? -- Don - Rochester, NY |
#3 posted 1213 days ago |
dovetail stitch it you will never move it to close -- cut it saw it scrap it SKPE: ANDREW.CARTER69 |
#4 posted 1213 days ago |
The block has actually been sitting in my shop for about a year now. As far as moving it goes, it takes a couple people and a lot of back ache to move it. I think the dovetail stitch is a great idea and I will probably end up trying that. As far as cutting it in half, I don’t think that is possible. I think (based on 4 doweled holes on opposite sides) that there are 4 threaded rods that run through it. -- Man is the only animal that blushes - or needs to |
#5 posted 1213 days ago |
How far in does the crack go? Can you route away the crack and replace that area? -- Gerry, http://home.comcast.net/~cncwoodworker/CNC_Woodworker.html |
#6 posted 1213 days ago |
Cutting it in two then re-gluing it back would sure seem to be the simplest approach -- David South FLorida http://ahunkahunkaburninlove.blogspot.com/ |
#7 posted 1213 days ago |
I haven’t actually counted the pieces, but there are well over 200. They are individual pieces of hard maple and they are faced so that the end grain is up. What I mean by this is that the cutting surface is made up of end grain. Cutting it in two – especially with the threaded rods through it would be impossible. There would be no way to get a clean cut as it is too thick. I don’t think routing would work either as the cracks are probably several inches deep. -- Man is the only animal that blushes - or needs to |
#8 posted 1205 days ago |
Ok…Here is a wild idea… You could cut out the cracked section in the shape of a square or rectangular chunk to get rid of the crack and then make a custom sized cutlery block that will flush fit in the section you cut out. Just a thought |
#9 posted 1205 days ago |
Cut it in half along the crack using a circular saw plus a sawzall or just a chainsaw smooth the two sides router out some pockets on both top and bottom to place some counter top hardware a couple on top and tom. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#10 posted 1204 days ago |
Thank you all very much for the ideas. mdbohica, I really like your “wild idea.” It does solve a few problems. I think what may work is for me to put in dovetail stitches where necessary, but maybe it would be wise to actually route the block and take off approximately 1 inch. I would then actually make a new cutting board about an inch thick and attach it to the current butcher block. This I think would get rid of any germ problem that may have developed at the dump. Jim, I really want to avoid cutting the block in half. It’s just sooooo heavy and I actually think there are threaded rods running through it -- Man is the only animal that blushes - or needs to |
#11 posted 1204 days ago |
If it were me, I’d drive some wedges into the crack and split the wood. hen I would surface the teo mating surfaces. Next I would clean them with acetone (in case there is any oil seepage). Then I woul reglue and clamp. |
#12 posted 1204 days ago |
What are you going to do with it if you get it fixed? -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#13 posted 1204 days ago |
I am actually planning to use it in my kitchen as a counter/cutting board/conversation piece. I’m in the process now of turning the legs and making the skirt underneath. I really hope it works out. Seems like a real shame to let that nice piece go to waste. -- Man is the only animal that blushes - or needs to |
#14 posted 1204 days ago |
Good luck, I suppose the worst possible case is to route out the crack and fill with epoxy. Maybe add a little something there for more of a conversation piece ;-)) -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#15 posted 1203 days ago |
I would leave it. It gives it character. It will never come apart. Something like this should be left alone for nostalgic reasons! The block will continue to be functional regardless. My $.02 -- Childress Woodworks |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
