Forrest 1/4 3/8 finger joint blade stuck together
Forum topic by Putttn posted 01-11-2016 11:40 PM 915 views 0 times favorited 10 replies Add to Favorites Watch
View Putttn's profile
Putttn
111 posts in 2184 days
01-11-2016 11:40 PM
Last year I purchased a Forrest 1/4-3/8 finger joint blade combo to use on my Saw Stop and Incra IBox. Just finally getting around to putting it all together and for some reason I can’t separate the two blades. Got the wax off but since I’m new to all this with the double blade I must be doing something wrong??
-- Bill eastern Washington Home of beloved ZAGS
10 replies so far
View pintodeluxe's profile
pintodeluxe
5567 posts in 2719 days
#1 posted 01-11-2016 11:45 PM
Are the blades only stuck together, or stuck on a center post in their package? My dado sets sometimes get hung up on the post in their storage container. Once I worked them loose, I shaved down the diameter of the post a bit to make installation easier.
Good luck
Putttn
#2 posted 01-11-2016 11:47 PM
Just the blades stuck together. And I mean they are really stuck.
pintodeluxe
#3 posted 01-12-2016 05:11 PM
Assuming nothing is wrong with them, they might just be stuck together with a vacuum effect like two plates of glass. Wax between the blades could have the same effect. Try compressed air, then some light oil to separate them. Don’t pry them apart.
View ChuckV's profile
ChuckV
3096 posts in 3433 days
#4 posted 01-12-2016 07:32 PM
You say that you purchased the blades last year. That could be anywhere from less than two weeks ago to over a year ago. If it has been a fairly long while, I wonder if some material used to protect the new blades has become very sticky. You could try giving Forrest a call.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View builtinbkyn's profile
builtinbkyn
1963 posts in 846 days
#5 posted 01-12-2016 08:03 PM
Maybe heat from a blowdryer? Nothing too hot, but enough to make what ever is binding them less viscous.
-- Bill, Yo!......in Brooklyn & Steel City :)
View 716's profile
716
502 posts in 822 days
#6 posted 01-12-2016 09:10 PM
-- It's nice!
Putttn
#7 posted 01-12-2016 09:37 PM
Yeah. I spoke w/Forrest blades and they suggested WD 40 and stay away from heat. Only problem is these two blades are really fused together and I’m not seeing anywhere to get the WD 40 to penetrate. I took my cheater glasses and a bright light to see if there was any type of opening and none. I’ll try it and see what happens.
View bandit571's profile
bandit571
19201 posts in 2589 days
#8 posted 01-12-2016 09:55 PM
Throw them into the freezer overnight….
View jusfine's profile
jusfine
2422 posts in 2831 days
#9 posted 01-12-2016 10:28 PM
I think I would try a couple pine wedges (maybe cut from a 2×4). Split it to make two small wedges.
There is no way they will bend the blades. I have the same set, they were stuck together but maybe not quite as bad as yours.
Tap them in from opposite directions, might just be suction and it may pop apart.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View gfadvm's profile
gfadvm
14940 posts in 2595 days
#10 posted 01-13-2016 01:09 AM
I’d tap a couple of finish nails in from each side. You shouldn’t hurt those blades at all as they are harder than the finish nails.
