Freud Router Plate Insert???
Forum topic by Scotty Stepp posted 01-25-2010 06:54 PM 4155 views 0 times favorited 2 replies Add to Favorites Watch
View Scotty Stepp's profile
Scotty Stepp
25 posts in 3559 days
01-25-2010 06:54 PM
I have a FT1702VCEK 2-1⁄4 HP Router and no way of using my template guide set without the insert that goes into the bottom of the router plate. I can’t seem to find anything that will work. Anyone help me out? Do I need to buy a whole new base for it? And if so…which one will fit?
Many thanks,
Scotty
2 replies so far
View davidpettinger's profile
davidpettinger
661 posts in 3197 days
#1 posted 01-25-2010 07:33 PM
Hey Scotty, Try these guys. You may be able to get a base plate only from them that will adapt to your Router.
http://www.jaspertools.com/routercompatibility.cfm
-- Methods are many,Principles are few.Methods change often,Principles never do.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3283 days
#2 posted 01-25-2010 07:50 PM
Sounds like you need the Template Guide adaptor Part # FT1100
http://www.freudtools.com/p-285-template-guides.aspx
Hope this helps
-- http://shepherdtoolandsupply.com/
