Oak pallet wood, joining/planing questions
Forum topic by asiago posted 01-11-2016 05:12 PM 657 views 0 times favorited 1 reply Add to Favorites Watch
View asiago's profile
asiago
14 posts in 1492 days
01-11-2016 05:12 PM
Topic tags/keywords: pallet wood oak hand plane question
Heya folks,
An oak pallet came into my workplace the other day, and the wood seems decent enough, so I figured I’d take the thing apart and use it. It was constructed with the crappy twisted shank nails that were on a roll with copper wire, so there’s copper bits here and there in the pieces I’ve reclaimed.
I want to construct panels with these pieces, then build a couple of boxes. Most of the pieces are between 3.5”-4” wide, 5/8” thick and 14” long, quarter-sawn as far as I can tell (rather roughly too). I will be using hand tools.
My main question is this: should I square the sides and edge join these pieces first, then hand plane them to thickness? Or should I (mostly) plane them individually first, then edge join them?
1 reply so far
View rwe2156's profile
rwe2156
3090 posts in 1624 days
#1 posted 01-13-2016 12:59 PM
If they are flat you can do that, but if the face surface is wavy or irregular, I would face joint one side then edge joint.
You also need to check them for twist.
