What is this blade used for?
Forum topic by Harry posted 01-11-2016 03:12 AM 1248 views 0 times favorited 23 replies Add to Favorites Watch
View Harry's profile
Harry
80 posts in 1180 days
01-11-2016 03:12 AM
This blade came with a used Unisaw I got and don’t know what it is used for. 10” – 3/8 kerf.
-- Harry - Professional amateur
23 replies so far
View tomsteve's profile
tomsteve
784 posts in 1219 days
#1 posted 01-11-2016 03:15 AM
i believe its used for making big pieces of wood smaller. :)
dont think ive seen a grind like that on a blade before.
View MrUnix's profile
MrUnix
6715 posts in 2199 days
#2 posted 01-11-2016 03:23 AM
V-groove cutter – typically used for scoring and folding stock.
View jbay's profile
jbay
2289 posts in 899 days
#3 posted 01-11-2016 03:53 AM
I believe it’s more just for decorative v-grooving material. Typically folding cutters don’t have the flattened tip.
CBW though
Harry
#4 posted 01-11-2016 03:54 AM
- tomsteve
You gave me a good chuckle.
MrUnix
#5 posted 01-11-2016 04:03 AM
I believe it s more just for decorative v-grooving material. Typically folding cutters don t have the flattened tip.
- jbay
Some do, some don’t… depends on the application.
V-Groove Cutter with 1/32 inch Flat Tip
Can also be used for decorative trim cuts as well.
Harry
#6 posted 01-11-2016 04:10 AM
- MrUnix
That makes sense Brad, It also came with a half dozen non-ferrous blades. The guy I bought the saw from (and a whole bunch of other tools) was an architect building a mega modern spec house with some materials I had never seen before.
View MadMark's profile
MadMark
979 posts in 1453 days
#7 posted 01-11-2016 04:17 AM
That blade is too thick to be just used for scoring. The special cut and the rust suggests that its a wet cutter for solid surface cutting.
M
View poopiekat's profile
poopiekat
4355 posts in 3734 days
#8 posted 01-11-2016 04:31 AM
I’ve seen blades like that for machining thick sheets of plastic, for fabricating leak-proof joints in water tanks and fuel cells.
Harry
#9 posted 01-11-2016 04:38 AM
M
- MadMark
EVERYTHING had rust on it that I bought :(
MrUnix
#10 posted 01-11-2016 04:41 AM
- MadMark
Maybe… but if you follow the link I gave above, it shows an 8” blade almost identical, with the same 3/8” kerf width, specifically for the task mentioned. And it is described as “Carbide Tipped V-groover for scoring and folding applications” (and is way expensive!! :)
Rust just indicates it hasn’t been used for a long while. I’ve had TS blades that were as rusty or rustier still installed on the saw when purchased, and certainly not used in a wet environment. Nothing that a little evapo-rust or electrolysis won’t take care of though.
Harry
#11 posted 01-11-2016 05:04 AM
It’s going into my electrolysis bath tomorrow. Wow those blades are $$$
View Woodknack's profile
Woodknack
11629 posts in 2380 days
#12 posted 01-11-2016 05:22 AM
It s going into my electrolysis bath tomorrow. Wow those blades are $$$
- Harry
Is that safe for the brazing? It probably is, but I never hear of anyone using electrolysis on carbide TS blades. I’m asking because I don’t know.
Harry
#13 posted 01-11-2016 06:42 AM
Is that safe for the brazing? It probably is, but I never hear of anyone using electrolysis on carbide TS blades. I m asking because I don t know.
- Rick M.
Good point, I just searched around a bit and didnt find a good answer yet. Guess I’ll wait with the bath, not like I need to use this cutter tomorrow.
View bandit571's profile
bandit571
20013 posts in 2683 days
#14 posted 01-11-2016 06:57 AM
I’d put it on the saw, raise it up, and run some pine through the saw, let the cut wipe the rust away..
MrUnix
#15 posted 01-11-2016 05:57 PM
- Rick M.
I’ve done carbide tipped blades and it didn’t seem to have any adverse effects on them. Maybe if you used one as the sacrificial anode it might though. But if you don’t feel comfortable with the process, then just dunk it in some evapo-rust instead. Laid flat in a shallow container, you wouldn’t need much and you can re-use it over and over again on all the other smaller rusty stuff you have. I have an old gallon paint can about half filled with it, with a wire basket in it for dunking nuts, bolts, washers and other little items. I love the stuff, and it’s also a lot less messy :)
Hold on a bit, and I’m sure others will chime in about other methods as well (citric acid, molasses, etc…)
