Mixing stained and unstained
Forum topic by Shay posted 01-25-2010 07:21 AM 990 views 0 times favorited 3 replies Add to Favorites Watch
View Shay's profile
Shay
59 posts in 3767 days
01-25-2010 07:21 AM
Let’s say you have a project which has 2 different species of wood. The first is the bulk of the project and is a common wood like oak which you’re required to stain. The second is an exotic wood which is only used as an accent like a spline or plug. My question is, is there a trick to staining the oak without touching the exotic? Assume that for this particular project you really can’t add the exotic wood after staining the oak because it requires some sanding and/or cutting. Or is this just not possible?
Thanks,
Shay
-- Centerville, MN - Hobbyist and DIYer
3 replies so far
117063 posts in 3543 days
#1 posted 01-25-2010 07:23 AM
Blue tape
View Icemizer's profile
Icemizer
88 posts in 3505 days
#2 posted 01-25-2010 02:50 PM
Shellac the exotic first. Stain the oak. Use alcohol to remove the shellac. Use whatever you are comfortable with to finish the piece.
-- Say what you mean and mean what you say.
View Shay's profile
Shay
#3 posted 01-25-2010 06:09 PM
Oh that’s a good idea Ice! Thanks!
