Just lost a large ash tree in the back yard, and need to clean it up. I am looking for suggestions on the best bang for the buck in a home owner grade chain saw. Size, brand, models, etc. I've owned two Poulan's previously that really haven't held up all that well. I don't want to spend a fortune, but would like this saw to last many years. TIA!
I needed a small chain saw to cut down a Pine tree in our back yard…
I ended up getting a chain saw from Harbor Frt. for about $50… Yes, $49.95 ….
Electric… 120 vac…
Need a good extension cord…
I started by just cutting the lower limbs off gradually leaving just the Trunk… Tree was only about 20' high…
Got on ladder & cut the top off as high as I could… the rest was a piece of cake.
It is a light-duty saw… but works great on the small-medium sized cuts…
On larger cuts you may have give it a rest now & then to get all the way through…
A great saw for just Trimming… Electric is good… don't have to mess with fuel, etc.
I really like it…
You DO NOT want to give it Heavy Duty use… be prepared to just taking a break once in awhile… When it needed a rest, I did too… so it worked out pretty good!
I can't complain about my gas Craftsman… I've used
it plenty, enough that I need to contemplate buying
a new bar for it. Keep the chains sharp and the
motor gets less strain… juts like plane irons saw chain
works better with frequent touch-ups in my experience.
You might look on the Forestry forums. They really
know chain saws.
I'm partial to the Stihl 250 myself. It's a good occasional use saw that will last forever as long as you take care of it. I have one and my grandpa who until he retired had been a logger since 1956 has one that became his go-to saw anytime there was storm damage to clean up.
How big is the tree and how often do you plan on using the saw? My FIL has a cheap electric and it's all he has ever needed. He has a small lot in town and just a few trees that he trims once every other year or so, and it's perfect for him. I live on a rather large chunk of land and have some rather large oak trees coming down once a month at least, so that electric thing would quickly be toast. Renting one, if this is a one time deal, is also a good idea and would let you get a larger saw that might be way more than you would want to spend otherwise.
Actually, the homeowner models are the ones with the bells-n-whistles to make it 'easy' for a clueless user. They are also built with lesser parts and won't last as long. But in general, Sthil is pretty much considered the best all around manufacturer behind Dolmar, and at par or a bit better than Husqvarna, Jonsered and Echo.
I tried a Poulan too. Just cheap garbage, disposable saw.
Most are… but the "Wild Thing" is an odd duck and frequently sought after by arborists. I had one that never failed me for almost 15 years of hard abuse and a couple dozen chains/sprockets. Had a cool paint job too
If you just need an occasional saw I would go with the Stihl MS170 or MS250. I have used both and if you can justify the MS250 get it. It has a bit more power and I think is built better,for a homeowner it will last may years. The advantages of the MS170 are it will only be about $200 and that should leave enough to get some fuel, a quart of bar and chain oil, and a file. Another advantage of that is it is only about 9 lbs. That was my first saw and now I am in the 95cc range.
I prefer to own it rather than rent, so I don't feel so helpless when I need it. A cord for an electric saw would have to be pretty long and would be a hindrance, so I'm definitely leaning toward gas. Stihl has always been the name I've heard is good, but I also hear good things about Husqvarna, Echo, and Jonsered.
One of my old Poulans was the Wild Thing. Had it for a few years before it began starting hard….is that worth trying to fix?
The tree is probably 60 feet long or saw with maybe a 24" diameter. I use them periodically…maybe 2-3 times per year…not a ton, but enough that I like to have one.
Another vote for the stihl ms 250. Probably called the 251 by now with the newer models. I bought one 12 years ago and it still starts right up. The nice thing about it is if you need to in the future, you can throw a larger bar on there in the case you need a larger saw. Me, I just bought another saw. I can justify it tho as I burn wood for heat and have been for eons. You absolutely cannot go wrong with stihl.
Stihl MS250 is what I have now. Be sure to learn how to start it properly. Any more than three or four pulls in choke mode floods it and you'll need to pull the plug and blow it off.
Then get the dirt cheap Harbor Freight electric chainsaw chain sharpener. I tried to sharpen by hand for so long, but never got consistent results. I bought the HF unit with a coupon for about thirty dollars and tax and was blown away by how nice my saw cut afterward. Big chips and nice and straight.
Also - GET CHAINSAW CHAPS and wear eye protection. You get one body in life - protect it.
A friend (chain saw enthusiast…probably owns 20 or so that he has owned/bought on Ebay/inherited/whatever) loves the "Echo" brand for the saws he actually uses. Might be because he tends towards US made. Our local dealer is a nice guy to deal with so that might explain it also.
Stihl is the best. No doubt. Personally I have a polen. A small 14 inch blade "wood shark" model. This summer I had three silver maple trees blow over in my yard. Took care of all three with it with no problem. These three make five I have done with it. It may sit for years but when I need, it runs great. Correct mix and 100% gas. NO ETHANOL! Ethanol will kill one faster then you think!
See you're in Rochester - I think you have Dolmar up there and if you have a good dealer you can buy one of those too with some confidence. Stihl is a no brainer, though. Use a good 2 stroke oil. The Stihl brand has a stabilizer in it, too.
Well, it if runs but just hard starting… it certainly would be cheaper to fix it than buying a new one
Might even fix itself if you run a tank or two with seafoam through it (it's good stuff!) and a little tweaking of the mix screws.
As for the ethanol, I've always just used the cheapest, lowest octane gas I can find… and around here, that is 10% or less ethanol. Never had a problem in any of my motors (lawn mower, rider, weed eaters, tiller, chainsaw, etc…). They have been using ethanol resistant fuel lines and carb parts for a very long time now. The real problem comes with water adsorption, which ethanol increases, and accelerates the formation of gum/varnish and sludge. As long as you run the thing dry and don't keep fuel in the tank when stored, you should be good to go.
Scott, You have never steered us wrong with your saw advice so I feel the need to repay the favor: Buy an Echo CS400. I have owned a lot of chainsaws over the years (lots of brands). I have had the Echo for 6 years felling trees for my sawmill, cutting firewood, etc. It is the best bang for your buck!!! I paid $300 for mine and the price has not gone up.
Advantages: very lightweight for an 18" saw, has never seemed underpowered, and if it doesn't start on the second pull, you forgot to flip the switch to ON !
Keep your chain sharp, use quality 2 cycle oil and it will be maintenance free ( mine is still on the original spark plug and air filter)
Have a Stihl MS 250 C-BE that i am happy about. And it is the lightest gasoline saw that i have ewer used - great for cutting trees from the top or pruning. The toolless chain adjuster is nice.
For gas i use this stuff fhat a pro recomended. No smoke at all:
I prefer Husqvarna XP 2 cycle oil. but Stihl also makes top quality 2 cycle oil. As long as you stick with a namebrand and not something like a store brand you should be ok.
If you do buy a Stihl you may have to use Stihl 2 stroke oil - it's dyed a different color and if you have warranty issues with the carb they will say you used inferior oil. My dealer told me that anyway, may have just been a scare tactic to get a few more dollars out of me. Put a little Seafoam in your fuel as well. I've had fuel in my Stihl saw and leaf blower and my Echo string trimmer for months at a time and never an issue. If you want to go nuts spend $50 for a gallon of Klotz synthetic.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
