lunchbox planer question
Forum topic by stratiA posted 01-25-2010 04:55 AM 1156 views 0 times favorited 3 replies Add to Favorites Watch
View stratiA's profile
stratiA
101 posts in 3615 days
01-25-2010 04:55 AM
Topic tags/keywords: planer
Good evening everyone. I just purchased the porter cable planer from lowes. I am aware that it is a clone of the delta shop master portable planer. I purchased it knowing its limitations. It will probably see only occasional use. The instructions don’t really tell you how thin it can plane to, or length. More or less what I am trying to say is if I resaw a board to 1/4 or even 1/8 inch can I plane it to clean up band saw marks and to final thickness. Or can I put a 12” piece through safely. Will I need to build a sled or something like that. any other advise would be helpful to avoid snipe, safety, etc
-- Strati Alepidis, Burlington, Ma, Member Red Sox nation
3 replies so far
View lew's profile
lew
12510 posts in 3995 days
#1 posted 01-25-2010 05:43 AM
12” is about as short as you would probably would want to use. There are techniques to make “runners” for short pieces so they can safely pass through the planer. As for thickness, most planers suggest 1/8” as the minimum thickness. You can make an insert to rest on the original bed. This will allow you to make thinner stock. When planing material thinner than 1/8”, it will have the tendency to shatter- especially in areas where the grain runs wild.
Rick Dennington
6351 posts in 3434 days
#2 posted 01-25-2010 06:10 AM
Greetings…..... What lew said sounds just about dead-on…....I have no further comments. He said it all.
-- " At my age, happy hour is a crap and a nap".....!!
View ajosephg's profile
ajosephg
1880 posts in 3801 days
#3 posted 01-25-2010 07:34 AM
What Rick said.
-- Joe
