How do I rip a 60 degree bevel on a board
Forum topic by robc posted 01-25-2010 01:03 AM 6917 views 0 times favorited 5 replies Add to Favorites Watch
View robc's profile
22 posts in 2981 days
01-25-2010 01:03 AM
Topic tags/keywords: bevel 60 table saw jig
I am building a lumber rack that mounts to the wall. The top support needs a 60 degree angle down the long face of the board. The matching support beams will have a matching 60 degree so they hook together. I can not figure out how to rip 60 when the saw only goes to 45. I am sure there is a jig but I can’t come up with one. Any ideas?
5 replies so far
View bigike's profile
4050 posts in 3225 days
#1 posted 01-25-2010 01:09 AM
use a sled with a piece of wood nailed to it so it holds the piece your cutting at the angle u want. If u have a wixey degree box u can get the angles u need, this is what i use to get mine.
-- Ike, Big Daddies Woodshop,
18229 posts in 3612 days
#2 posted 01-25-2010 01:24 AM
If you cut 30 degrees off one side, the other piece will have a 60 degree bevel.
Edit: forget that, we’re working on a falt surface with a table saw :-)) It will be 150, not 60 :-((
Edit #2, If you stand the board up on edge with the saw set at 30, the other side will be 60 degrees.
View papadan's profile
3584 posts in 3305 days
#3 posted 01-25-2010 01:26 AM
Ooops,Took too long thinking about it!
View Vicki's profile
1090 posts in 3281 days
#4 posted 01-26-2010 07:36 AM
It almost sounds like you are talking about a french cleat.
-- Vicki on the Eastern Shore of MD
View robc's profile
#5 posted 01-27-2010 03:05 PM
Thanks guys. I was able to cut it with the board standing on edge.
