Forum topic by ClaudeF | posted 01-10-2016 04:40 PM | 687 views | 0 times favorited | 6 replies | ![]() |
Topic tags/keywords: santa bear progress tutorial basswood A rough out is not always necessary for carving. I began this project with a photograph of what my customer wanted and a block of basswood 12×6 x 3 inches. I copied the photo to the block front with carbon paper and the side views were my best guess as to what they should look like, as I only had the photo for the front. I then cut out the outline on my bandsaw. Claude |
#1 posted 01-10-2016 04:42 PM |
The next step was to begin removing the waste wood and creating my own rough out from the cut out. |
#2 posted 01-10-2016 04:46 PM |
With much of the waste wood removed, I could now begin the detail carving. In this photo you can see that the details of the face are pretty much finished, as is the belt. I tend to carve a little bit here and a little bit there all over the carving instead of trying to do one spot all the way to done. I usually do the face earlier, as if I mess up or something breaks, I can always carve deeper and create a new face. |
#3 posted 01-10-2016 04:51 PM |
The carving of the details is now complete and the painting can begin. Notice the “mat” in the final photo? This is just a piece of rubberized drawer liner. I put it on the bench so that the carving will not slide around so easily. I use the same drawer liner between the wood block and the bench when I clamp the block down with F clamps so I can use a mallet and gouge. The rubber keeps the carving steady and doesn’t allow it rotate under the clamp. |
#4 posted 01-10-2016 04:54 PM |
The painting is now complete. I’m only putting one photo here – the rest of the complete photos are in my projects. When I paint something like this, I do the white areas first, then the thin washes, such as the face (burnt sienna, thinned with water 1:12). Claude |
#5 posted 01-11-2016 01:07 AM |
t almost all my blocks. Then use my Fordom to round things out anymore. -- A childs smile is payment enough. |
#6 posted 01-11-2016 02:01 AM |
Just flat out amazing! |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28056 |
CNC Woodworking
212 |
Hand Tools
5407 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
