Routing Door Casing
Forum topic by BigDaddy1966 posted 01-10-2016 01:20 AM 730 views 0 times favorited 9 replies Add to Favorites Watch
View BigDaddy1966's profile
BigDaddy1966
25 posts in 1091 days
01-10-2016 01:20 AM
I am getting ready to remodel my office and will be making all new base boards and door casings out of Red Oak. I did some practice pieces and they come out what I will call wavy and not smooth. I am running my router at 10k rpm, feed rate of medium to slow and have a double stack set of feather boards right before the bit. The bit is a brand new Freud so it should be sharp and the router is a 3 1/2hp, so why can’t I get these casing boards to come out smooth.
Any help would be greatly appreciated.
-- Brett Walker
9 replies so far
View MadMark's profile
MadMark
979 posts in 1626 days
#1 posted 01-10-2016 01:23 AM
Make two passes. First pass have the fence 1/16” proud. Then come back and do a slower clean up pass after resetting the fence even.
M
View Luthierman's profile
Luthierman
221 posts in 1260 days
#2 posted 01-10-2016 01:24 AM
Pictures would be very helpful in us diagnosing your problem. Most likely your problem is caused by something in your setup having some play. Are you using a fence? Have you tried feather board for both the in-feed and out-feed?
-- Jesse, West Lafayette, Indiana
BigDaddy1966
#3 posted 01-10-2016 01:28 AM
I am doing it in 3 passes with the last being the shallowest cut.
I do use a fence but I have not tried a set of feather boards on both the in and out feed sides only the in feed side
-- Brett Walker
MrUnix
7004 posts in 2372 days
#4 posted 01-10-2016 01:29 AM
What size bit are you using? 10K is pretty slow unless you are using like a 2.5” or larger diameter bit.
BigDaddy1966
#5 posted 01-10-2016 01:34 AM
The bit is 1 5/8 dia and height is 2 1/2.
-- Brett Walker
MrUnix
#6 posted 01-10-2016 02:06 AM
If it’s the 99-315, then you are spinning it way to slow… it’s designed to run in lower HP and single speed routers, so can do up to 22K easily.
BigDaddy1966
#7 posted 01-10-2016 02:43 AM
It’s the 99-465 casing bit.
-- Brett Walker
View AlaskaGuy's profile
AlaskaGuy
4632 posts in 2482 days
#8 posted 01-10-2016 02:58 AM
FYI there’s lot of router bit speed charts on the Internet. That bit should be @ 18000-22000 RPM’s
BigDaddy1966
#9 posted 01-10-2016 03:45 AM
Thank you for the feedback I will give it a try this week and see how it goes
-- Brett Walker
