To pocket hole or not to pocket hole.
Forum topic by Huckleberry posted 11-09-2007 05:07 AM 1677 views 0 times favorited 12 replies Add to Favorites Watch
View Huckleberry's profile
Huckleberry
218 posts in 4090 days
11-09-2007 05:07 AM
My next project is a mission style futon with three drawers under it. So lets start here, the wood I am using is 4/4 red oak. So here are my first two mistakes most of us know that once you mill 4/4 you are now about 5/8” on your material. A lesson learned in a dumb way. And I am starting to find that red oak is prone to cracking when using fasteners. I decided that since I wasted so much time on my table making mortise and tenons that I would use the Kreg pocket hole jig to as the primary jointing. However when I started joining the project I started splitting the wood. So I went to a #6 1 1/2” screw and you guessed it went right through the other side. So I guess that this is the learning curve of wood working. The biggest question that I have for you guys how solid is this type of joint? I have heard that nothing matches the strength of the mortise and tenon joint. I guess that I am trying to get years of wood working experience in a few hours.
-- I cut it twice and the damn thing is still too short!@#$% https://kata.sendlane.com/view/diyers
12 replies so far
dennis mitchell
3994 posts in 4551 days
#1 posted 11-09-2007 05:17 AM
I use a special screw made for pocket screws just so the wood doesn’t split. A pocket hole with a regular screw will split in just about any wood. It is a pan head 1 1/4” self tapping square head screw.
View gizmodyne's profile
gizmodyne
1780 posts in 4327 days
#2 posted 11-09-2007 05:22 AM
These joints are strong when reinforced with glue. However, there are no shortcuts. Consider the mortise and tenon again for some parts of your futon. Are you working off of a plan?
-- -John "Do I have to keep typing a smiley? Just assume it's a joke."
View Betsy's profile
Betsy
3392 posts in 4133 days
#3 posted 11-09-2007 05:27 AM
Huck – not sure, I defer to other LJ’s on this – but it would seem to me the M&T joint would be better on joints that will get some major stress such as a futon where people are going to flop down on it during the day and tossing and turning at night. I don’t think, even with glue, that a pocket hole screw joint would be long lasting in this application. They are really more suited to low stress joints – like face frames and small tables.
And as Dennis says just any old screw won’t do for pocket holes. You need a self tapping screw.
Just my 2 cents. Good luck on your project.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
Huckleberry
#4 posted 11-09-2007 05:30 AM
Yes and no. U-Build is were I got the original plans but my wife wanted drawers under the seat. So using a CAD program I copied some of the plan then put my ideas in there and once it was approved by my wife, you guessed it she justed passed by, I started to build. Hey Dennis I started using the Kreg screws but that split every thing, but I was using course thread would there be a difference if I used the fine threaded kind?
Betsy
#5 posted 11-09-2007 05:36 AM
Yes, the threads make a huge difference.
View Max's profile
Max
56000 posts in 4510 days
#6 posted 11-09-2007 05:38 AM
Huck,
Kreg has two different screws, a course thread for soft woods and a fine thread for hardwoods such as oak. Also the screw should not be screwed into the end grain of the wood but from the end grain into cross grain if that makes sense. Sometimes if the screw is too close to the end it will split the piece that it is being screwed into I have found.
I also agree with Betsy that the best joint for this type of project would be a mortise and tennon.
dennis mitchell
#7 posted 11-09-2007 05:43 AM
Was it a kreg pocket hole jig and kreg pocket hole screws? I had a similar set up but the tip on the fancy drill bit broke the first time I used it. Pocket hole joinery is ok for face frames and such, but if its going to get a lot of stress like a chair I’d look for other kinds joinery. Dowels, bisquets, loose tenons…splines. I often just use a screw that is covered with a plug.
35152 posts in 4637 days
#8 posted 11-09-2007 05:44 AM
I agree on the M&T. Don’t give up too fast on that joint. It does take some perfecting but it’s a good strong joint. You might also try loose tenons. But for them you are attaching the end of one board into the edge of another. It’s made up of 2 mortises and a loose piece of wood that is the tenon. You can use them when the boards are too short to use a real tenon.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
Huckleberry
#9 posted 11-09-2007 05:45 AM
I am so glad that I hooked up with all of you. That is where most of my problems are, I was indeed going into the end grain. Thanks for making think about that.
View Thos. Angle's profile
Thos. Angle
4444 posts in 4199 days
#10 posted 11-09-2007 03:06 PM
I’m with Dennis and Karson on this one. The pocket screws work well for cabinet carcases and faceframes and some other places in furniture. On anything that is going to get a bunch of stress and strain use a different joint.
Slow down and learn to do the mortises. They really don’t take that long by hand , it’s quiet and repetitive. By the by, 4/4 when milled should come out at 7/8, 13/16/ or 3/4 unless you want it 5/8.
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 4194 days
#11 posted 11-09-2007 03:35 PM
Pocket hole joinery is great, and very strong in the right situation. You have to use the right screw for the type of material you are working with, and I have actually pre drilled in situations like end grain etc. You might also consider loose tennon joinery like the Beadlock system. I have this system and it is easy to learn and use, does a nice job and would be allot stronger than pocket screws for what you are doing. Not too expensive either, and they sell a router bit so you can make the tennon material yourself. Or, if you have allot of disposable income you could buy a Festool domino!
View TomFran's profile
TomFran
2959 posts in 4231 days
#12 posted 11-09-2007 04:36 PM
Ditto to what Brad Nailor said! Pocket holes have their place. It all depends on the application needed. The same is true for biscuit joinery. Mortise and tenon joints can be faulty too, if they are not carefully and accurately crafted. A sloppy M&T joint can be weaker than a pocket hole.
