general international saw motor to baldor motor question?
Forum topic by ken_c posted 01-24-2010 07:13 AM 1299 views 0 times favorited 9 replies Add to Favorites Watch
View ken_c's profile
ken_c
323 posts in 3191 days
01-24-2010 07:13 AM
has any body done a GI motor (Taiwan made) to Baldor motor conversion?
9 replies so far
TopamaxSurvivor
18292 posts in 3704 days
#1 posted 01-24-2010 09:27 AM
NO, but Baldor has been around a long time and has a good reputation.
View knotscott's profile
knotscott
8057 posts in 3404 days
#2 posted 01-24-2010 11:57 AM
I haven’t done that swap either but thought I’d read that the General line made in Canada uses Baldor motors. Very well regarded motors, and as long as the size and motor specs are compatible, it should be a good move.
View DaveBaker's profile
DaveBaker
67 posts in 3780 days
#3 posted 01-24-2010 02:00 PM
Baldor is a very good motor. As long as the size, etc matches, I would do it. You may even be able to up the HP some as long as you have space for it and the footprint for mounting is the same.
-- Upstate New York -- Do what you love and never work a day in your life.
View Dave's profile
Dave
26 posts in 3096 days
#4 posted 01-24-2010 03:21 PM
My Table saw is a GI and the motor went on it. It was under warrenty they sent me a Baldor replacement.
-- Dave
View 8iowa's profile
8iowa
1580 posts in 3790 days
#5 posted 01-24-2010 03:31 PM
A/C induction motors are standardized by NEMA. Therefore, within a given HP, speed, and frame size, motors from different manufacturers are interchangeable. This standardization also applies to torque curves, and full load amps as well.
View PBthecat's profile
PBthecat
53 posts in 3079 days
#6 posted 01-24-2010 04:47 PM
No reason to swap out unless the GI motor fails, if I had to do a replacement the Baldor would be preferred but I’m guessing it would cost a lot more. In that case, stick with the GI OEM.
-- "Every hundred years, all new people"
TopamaxSurvivor
#7 posted 01-25-2010 12:17 AM
8iowa, do all the foriegn motors meet NEMA requirements?
ken_c
#8 posted 01-25-2010 04:58 AM
the mount on the baldor does not match the mount on the general international mount. the baldor mounts are narrower than the GI mounts. My motor is going and I have already priced out a replacement Taiwan one and a baldor. They are about the same but the baldor wont fit without modification to the mounts. i.e. cut them off and the weld them back on – not a good idea on a brand new motor. Hench – I was wondering if anyone had done such a modification or found a way to do it without cutting and welding – guess not…
TopamaxSurvivor
#9 posted 01-25-2010 05:19 AM
If you take you old motor to Grainger, they should be able to find one with the same mount for you.
