Environmentally Friendly Finishing Products?
« back to Sweating for Bucks Through Woodworking forum
Forum topic by Dryad posted 2021 days ago 1012 views 1 time favorited 6 replies Add to Favorites Watch
View Dryad's profile
Dryad
2 posts in 2021 days
2021 days ago
Hi, I’m setting up my own shop, and I want to be able to move away from using the typical stains & finishing products I’ve been using towards something that is environmentally friendly. However, I’m concerned about what the quality of those items would be like.. I’m assuming water-based stains as opposed to oil, and wax finishes, etc.? I have very little experiences with materials other than oil-based finishes, solvent-based laquers & polyurethanes. What I want to know, are there any recommendations out there on stain/dye/topcoat product lines that can be used with good results in a shop?
18320 posts in 2330 days
#1 posted 2021 days ago
this is a great topic, Dryad. I can’t wait to see the results.
View Dorje's profile
Dorje
1761 posts in 2166 days
#2 posted 2020 days ago
I;ve used Tried&True products and also here’s a link to a local outfit called Environmental Home Center; I guess their new name is ecohaus
Check out the finishes they carry located toward the bottom of the page under “Interior stains & clear finishes.”
Douglas Bordner
3907 posts in 2233 days
#3 posted 2020 days ago
Shellac is very eco-friendly. You eat some every time you take coated pharmaceuticals, fancy chocolates. Alcohol is the only solvent.
The water-borne finishes are sure to be more friendly than lacquer, or oil-based products which utilize drying agents.
You should look over Jeff Jewitt's website, as well as Target Coatings. I swear by the Oxford Ultima spray acyrlic lacquer. So much less toxic and fuel-air bomb scary than shooting Magnalac, Deft, etc.
Dryad
#4 posted 2018 days ago
Hi all,
Thanks for the information and greetings. I went to the websites mentioned, and they gave me a wealth of info that will give me a good place to start with products to try. I’ll experiment with them over the next few months, and will post on here how they worked for me. Thanks again!
Meagan
View Kaleo's profile
Kaleo
201 posts in 2309 days
#5 posted 2018 days ago
I use a product called Livos oil. It’s completely made from plants and from what I know it is the only oil finish that is approved by green peace. They make a range of different product that are all compatible. they make oils with stains in them if you want to stain a piece. The product is generally used for floors, but I have been using it for 2 years now and it works great. The only thing is that it takes time to build it up. You have to get like 8 coats on to get a really nice sheen, and you have to wait eight hours in between coats.
-- Kaleo , http://www.kalafinefurniture.com
View frank's profile
frank
1492 posts in 2375 days
#6 posted 2018 days ago
—-and by the way, thanks for the information on Livos Oil Kaleo!
I checked their website and found that they have a supplier up in my neck of the woods here….
Thank you.
GODSPEED,
Frank
-- --frank, NH, http://rusticwoodart.tumblr.com/
