How to save lumber that got wet??
Forum topic by LJR posted 01-23-2010 09:29 PM 7720 views 0 times favorited 4 replies Add to Favorites Watch
View LJR's profile
LJR
2 posts in 3554 days
01-23-2010 09:29 PM
Topic tags/keywords: question
Help! I bought some quarter sawn red oak for a project today and brought it home in the back of my truck bed. It started to rain and it got wet. How do I properly dry it to avoid any warping?? My workshop has a heated floor and the temp there is around 68 degrees. Do I just lay them out on some support boards to dry? How about wraping in newspaper – will that draw the moisture out? Thanks in advance for your advice!!
LJR
-- Lona, MN
View reggiek's profile
reggiek
2240 posts in 3504 days
#1 posted 01-23-2010 10:01 PM
It depends on how much moisture the boards were exposed to….if it is just surface moisture…then a quick dry would work just fine – I have used a hair blow dryer…or a heater…blowing on the boards lying on a flat surface….if the moisture was enough to infuse the grain….you would want to air dry on a flat surface with a flat weight on top for a few days or so….to keep the boards from cupping/warping. If you know someone with a kiln that would be the best for really soaked wood. If the wood cups/warps…a jointer and or planner would be the way to go.
View bob101's profile
bob101
333 posts in 3684 days
#2 posted 01-24-2010 05:09 AM
My stock gets wet during transport all the time if its not soaked threw the grain and you have time to wait ,a couple days of air drying should be good, especially in a dry heated shop. as above if it moves start up the jointer and make some lite passes to true it up.
-- rob, ont,canada
View Tim Dahn's profile
Tim Dahn
1577 posts in 3799 days
#3 posted 01-24-2010 05:45 AM
If the wood is wet from the ride home, just bring it in the shop, it will dry fine. You can always cut up some scrap for spacers (3/4×3/4) and stack it. put the spacers about a foot apart and add some weight to the to of the stack.
117416 posts in 3811 days
#4 posted 01-24-2010 05:49 AM
just stack it so it drys equally on each side
