temporary through mortise with a peg?
« back to Joinery forum
Forum topic by leftcoaster posted 01-08-2016 01:54 AM 945 views 0 times favorited 8 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
203 posts in 785 days
01-08-2016 01:54 AM
Topic tags/keywords: mortise tenon temporary structure
Sorry, but I don’t know what to call this and I’m wondering if it even exists.
I want to build a temporary outdoor structure out of 2×4s. Historically I have done it with some Simpson strong tie joists holding three 2×4s together and that has worked fine.
I was wondering if I could do something a little more attractive: The posts would have two mortises and the horizontal members (rafters, but not really) would have tenons that go through and beyond the end of the mortises. There, there would be a peg that would go through the tenons and so prevent the tenon from being pulled back through the mortise.
It’s a temporary structure, so I’d want to be able to disassemble it, hence no glue.
Has anyone ever seen such a thing? Is there an alternative approach? Would what I’m describing work?
8 replies so far
View conifur's profile
conifur
955 posts in 1060 days
#1 posted 01-08-2016 02:04 AM
Yes, it called a through tenon with a peg, the peg is tappered. Let me see if I can find a pic.
https://www.google.com/search?q=through+tenon+with+a+peg&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwi6iJPwj5nKAhVL7hoKHU4lCPMQsAQISw&biw=1366&bih=635
View TheFridge's profile
TheFridge
8908 posts in 1395 days
#2 posted 01-08-2016 02:33 AM
Or a t-bridal.
View bearkatwood's profile
bearkatwood
1478 posts in 920 days
#3 posted 01-08-2016 02:35 AM
I believe that the tent that housed the ark of the covenant in the bible was made somewhat like this so it is not a new thing. It should work just fine.
-- Brian Noel
leftcoaster
#4 posted 01-08-2016 03:33 PM
Thanks all, really appreciate it. It was fascinating to learn how offset holes for the peg were used in the absence of glue to hold the shoulders of the tenon against the mortise. The more I learn about joinery, the more I admire the ingenuity of the craftsman who developed these techniques.
Last question: as I mentioned, I’ll need to disassemble this for storage. Any particular tips on accomplishing that? The tapered pegs seem designed to achieve a firm joint and would, by design, be rather difficult to take apart.
conifur
#5 posted 01-08-2016 03:39 PM
View dday's profile
dday
138 posts in 1338 days
#6 posted 01-08-2016 03:56 PM
Yes. you see benches in Colonial-era National parks that are assembled like this.. two shaped ends with seat boards between them, all fastened and pulled together using just this method.
View geekwoodworker's profile
geekwoodworker
371 posts in 1369 days
#7 posted 01-08-2016 04:09 PM
The tapered pegs work best. The peg and the hole are tapered to match (approx. 5 degrees). They are actually easy to remove with a light tap of a hammer to the bottom of the peg. As a bonus if they become slightly loose due to wood shrinkage you can tap the peg in a bit and it is tight again.
Enjoy the build and good luck.
leftcoaster
#8 posted 01-08-2016 04:16 PM
This is really great advice. Thank you all very much.
