Plywood door for wine cellar
Forum topic by benihun posted 01-23-2010 02:16 PM 1822 views 0 times favorited 3 replies Add to Favorites Watch
View benihun's profile
benihun
33 posts in 3555 days
01-23-2010 02:16 PM
Topic tags/keywords: question plywood modern
Hi folks!
I’m wondering if a simple sheet of plywood worked for a door outside.
I want the most simple/easy-to-do solution for a door for our wine cellar entrance. I have the lock, the hinges and actually a “door” which has raveled/rotted/broke apart being old and it was a bad construction anyway.
Click on the image to see other pictures showing the details.
old cellar door
Is it that simle that I buy a sheet of plywood, have it cut to size, finish it with some outdoor lacquer, and screw it on the hinges and screw the lock on it?
Maybe, the hinges (or tabs or straps; I don’t know the appropriate word for that) need to be replaced by new ones in order to avoid the wobbling, that way preserving the new door.
Thanks for the answers, tips in advance!
3 replies so far
View rhett's profile
rhett
742 posts in 3576 days
#1 posted 01-23-2010 02:54 PM
Marine grade ply will work. Any other will breakdown and delaminate over time, unless sealed with a marine epoxy. Also through bolt the straps on instead of just screwing them to the face.
-- Doubt kills more dreams than failure.
benihun
#2 posted 01-24-2010 09:58 PM
Thank you!
You read my thoughts. What I really was unsure about is what you explained.
View B0b's profile
B0b
104 posts in 2599 days
#3 posted 02-27-2017 05:18 PM
Did you try it? Did it work out? I am working on something similar. Thanks.
-- Time to get started
